Thread: I Have a couple questions.
Results 1 to 5 of 5
  1. #1 I Have a couple questions.
    Aug 2008
    Pennsylvania
    This is my first one for now. =) Well in my GP the passenger door has a handle that works but you gotta play with it a little i was wondering if there is any guide to removing and replacing the handle?
    Got another one now...where can i get a scematic drawing of the drive belt (serpitine belt) and pulleys?
    Question 3: now i have the serpitine belt (or how ever you spell it) with the supercharger and the two other tensioners and idler on it. (when i took off the belt there was no rattling noise so i know its one of the 4 pulley's. Now there is a rattleing noise on one of these pulleys how do i figure out which it is?
  2. #2 Re: I Have a couple questions.
    SE Level Member Keet04GTP's Avatar
    Jul 2008
    Tulsa
    Quote Originally Posted by thenervemann View Post
    Inside or outside handle?
    2004 White GTP...Stock Stock Stock...Soon...3.0 ZZP MPS, ported blower, Pacesetter Coated Headers, FWI, Tuned PCM, VS cam, 105# springs, JP timing chain, whisper resonator and custom exhaust...My next goal(after I rebuild my savings)... 2.5" IC, 2.6 pulley, XPZ Cam, S3 heads, and a tranny....
  3. #3 Re: I Have a couple questions.
    Apr 2008
    Chillin at the Beach , VA
    If it is the outside handle, I can almost garuntee that the little round plastic piece that the rod that pulls the latch to open the door slides through, is broke. I went through the same thing with mine. If it is broke, I'm sure you can but another on. I ended up making my own out of somthing a little thicker.
  4. #4 Re: I Have a couple questions.
    Aug 2008
    Pennsylvania
    Ya its the outside handle...how hard is it to replace?
  5. #5 Re: I Have a couple questions.
    Apr 2008
    You gotta pull the door panel off and there are 2 bolts holding the handle on. You just have to play around with it to get it to pop out the door. It's not really that hard. Once you get the door panel off, you'll be able to see the back of the handle and see if the plastic tube(about 1/4 inch long)is broke. If it has fallen off, the rod would pop out the handle.
  1. I Swedish guy with a couple of questions
    By tdacke in forum General Tech Discussion
    Last Post: 05-14-2008, 05:27 PM
  2. got me a couple of new toys!
    By s1795so2 in forum Off Topic Discussion
    Last Post: 04-08-2008, 10:04 AM
  3. Been on a couple other sites, but new here
    By louie40GT in forum Introductions/Noob Questions
    Last Post: 02-23-2008, 01:06 PM
  4. couple questions on my gt
    By 59chevy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-04-2008, 08:58 PM
  5. Need a couple PN's.....
    By Iron Indian in forum Off Topic Discussion
    Last Post: 01-02-2008, 09:55 AM
