Thread: dumb question but?
Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
  1. #21 Re: dumb question but?
    Palmdale
    so i just used the air compressor w/ the injectors back in there hole. That seemed to have worked!! Just pulled on the evap hose and broke the nipple off on the IM. Damn it!!!!
  2. #22 Re: dumb question but?
    Palmdale
    Hey in Dubob Richie video on how to change a LIM gasket does he use break fluid cleaner to wipe down where the gaskets go? I know he mentions something about starter cleaner. Is break fluid cleaner OK to use?
  3. #23 Re: dumb question but?
    Palmdale
    so I got new valve cover gasket and not to sure if I need them, I notice some oil on the front exhaust manifold. The thing is not am not to sure how old this oil is? I just got the car and could not drive it anymore due to the water pump failing. I just want to make sure I am not wasting my money replacing gaskets that are fine. Here is a picture of one the gaskets. Also when replacing the coolant elbows I only got 3 washers with the new tensioner, how many are suppose to come with it?
  4. #24 Re: dumb question but?
    even if they look good just replace them. They get flat on one side and start leaking.
  5. #25 Re: dumb question but?
    Palmdale
    sounds good to me, its pretty funny. I took my in car in to get a diag and they said it was the tensionor. The car was making a whining noise from the engine bay, it turns out it was the water pump. It started spewing water everywhere. Not good. So I just replaced the water pump and put a new tesnisonor on there too. Next is to finish up the LIM and Valve cover gasket. I need to replace the vacuum lines I broke. So does anyone know why Duralast gives you 3 O-rings in the w/ the new tensionor? I watch a video from A1 on you tube and did not notice him say anything about those O-rings
  6. #26 Re: dumb question but?
    SE Level Member fastmvr's Avatar
    Jan 2012
    Fate, TX (DFW Area)
    Great Thread....I am in the middle of doing my LIM gasket change myself. I also broke that multi-hose fitting on top of the SC. It was too brittle to even twist the hoses before trying to remove. Any idea what that multi-hose fitting is called? I will post up a pic in a few minutes.
  7. #27 Re: dumb question but?
    Out West
    T fitting?
    Whine with your Cheese?
  8. #28 Re: dumb question but?
    Jan 2012
    Fate, TX (DFW Area)
    You don't need to remove that when doing LIM gaskets...
    I was gonna post a pic but I noticed the pic of "that" is what I also broke. Any idea what the parts counter would call this?
  9. #29 Re: dumb question but?
    It's a dealer thing or a ZZP thing
    Eaton - EATON Blower Booster Cap #ETN-312065
    On the extra three o-rings.. who knows. Use the ones on your elbows and smile that they are new.
  1. Might be a dumb question, but...
    By SteveCZ28 in forum General Tech Discussion
    Last Post: 02-19-2011, 11:06 AM
  2. Dumb Question?
    By trenaro in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-26-2011, 06:59 PM
  3. dumb question
    By Mike8410 in forum General Tech Discussion
    Last Post: 01-10-2011, 10:27 PM
  4. Hopefully Last dumb AC Question
    By guitarguyucf in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2010, 12:48 PM
  5. Dumb question (Oil)
    By JCG's-GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-03-2008, 12:10 PM
