Just to throw this out there. I have heard complaints that the Dorman/Motormite/Help coolant elbows like to leak around the O-Rings, but that is not the problem I've had with the last few sets I've bought. On two separate occasions, within 8 days of each other, I've had my upper coolant elbow (only one on the '97) essentially blow out from the manifold side and fold in on itself. Both times, the piece has been split along the inner portion of the elbow after retrieving it. The O-Rings, in both cases, looked to still be in great shape. Has anyone else seen/had this happen? BTW, Each time this occurred, I was WOT.
My fix was to scuff up the outside of the elbow and apply some JB Stick Weld to form a triangular shape across the two legs and hopefully prevent the previous problem. This was done a week ago, but I haven't been able to really test its strength as I have another issue that needs to be addressed...
