Thread: Car died. Need help quick....:(
Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
  1. #21 Re: Car died. Need help quick....:(
    SE Level Member hunter_alexander's Avatar
    Erie Pa.
    lol you guys crack me up.
    So you think that is the problem?
    What causes it? Is it the resistor going bad or the pump? New to electrical problems on my GTP. Its been a good car, never an issue for 160k miles. All of a sudden started acting up.
    If all else fails, throw money at it..... that'll fix it.
    Check out my website here: http://craig.beesky.com/1987_olds_cutlass.htm
  2. #22 Re: Car died. Need help quick....:(
    Resistors build up heat and often they are nothing more than a glorified wire wrap... it develops a break in the wire...when it's cold it makes contact. Heats up..expands and presto..no connection.
    It's one of the most common things on a SC's W body. I pulled up to the neighbors house... got back in the car it started and stalled. Started and stalled again, I got out, bent the tab and since that day this summer, I haven't touched it.
  3. #23 Re: Car died. Need help quick....:(
    Erie Pa.
    ok, I did the relay tab bend.
    I guess Ill find out if that is the problem or not. Since it is only an itermittant problem, I just have to wait and see if it does it again or not.
  4. #24 Re: Car died. Need help quick....:(
    Erie Pa.
    I take it that with the sc w body cars this is a common issue?
  5. #25 Re: Car died. Need help quick....:(
    Yes...they are total crap boxes. There is just nothing like an H body Bonneville or G body Park Ave for luxury and comfort while being supercharged and underestimated sleepers.
    If you have to have a W body.. I'll always recommend a Regal.
  6. #26 Re: Car died. Need help quick....:(
    Stealing my chance at glory huh, I see how it is.
  7. #27 Re: Car died. Need help quick....:(
    I gave you credit for the pic... Can't help it if the guy could have pushed his car home by the time you post.
  8. #28 Re: Car died. Need help quick....:(
    I know lol, I was sleeping, so someone had to help.
  9. #29 Re: Car died. Need help quick....:(
    Erie Pa.
    Thanks everyone. Hasnt done it again yet.
    Question though, is the problem with the fuel pump? The fuse relay?
    I want to make sure that if it is something I need to replace, that I get it done. I dont want to end up on the side of the road later.
    thanks
  10. #30 Re: Car died. Need help quick....:(
    Antioch, IL
    Your problem is the resistor its old dead and needs to be replaced if you dont wanna run in high all the time. The pump itself is fine
    Part # 88951182
    88951182 - GM RESISTOR KIT
    Shop around google with the part number to find it cheaper
    I got mine from parts giant.
    2009 Challenger SRT8
    Expert at being gay.
  11. #31 Re: Car died. Need help quick....:(
    I'm lazy....and still running in high mode since early summer
  1. my maf died
    By nascartech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-21-2011, 12:39 AM
  2. My car died
    By GPGTkid01 in forum General Tech Discussion
    Last Post: 10-20-2009, 08:25 PM
  3. died
    By Cjs02GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-08-2009, 08:46 PM
  4. So..... The gtp has died... =[
    Last Post: 08-08-2009, 02:55 PM
  5. died
    By justaV6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-09-2009, 06:21 AM
