Thread: P0341 help!
Results 1 to 6 of 6
Threaded View
  1. #1 P0341 help!
    Feb 2008
    Got a P0341 code a few weeks ago. I replaced the cam sensor today, but I continue to get the code.
    Symptoms are:
    -Rough idle (Rougher than the typical XP idle)
    -Occasional popping on decel (low rpm)
    -Reduced MPG's
    -Random Cruise KR (1* Max)
    I can clear the code and it immediately shows back up as pending.
    Watching the scanner, I don't see anything amiss in my scanned parameters.
    I did check the wiring the best I could while changing the sensor and didn't notice anything obviously wrong.
    Anyone else have any similar issue with a solution?
    **NOTE** I have been having the cruise KR problem for a little while (few months) before I had this code pop up. I did, however, have two coolant elbow blow-outs within 8 days of each other shortly before this code appeared. (Not really sure if that caused anything, but I'm trying to provide as much info as possible here.)
  1. P0141 p0341 p1351
    By jkwidener in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-25-2011, 08:22 PM
  2. Bad idle and RPM issues not to forget codes P0303, P0341, AND P0300
    By jessiinicole in forum Off Topic Discussion
    Last Post: 03-08-2010, 02:27 PM
  3. Error codes p0341 and po300
    By jessiinicole in forum Introductions/Noob Questions
    Last Post: 09-09-2009, 04:34 PM
  4. P0341 OBD-2 code
    By icolex1 in forum General Tech Discussion
    Last Post: 02-22-2009, 10:19 PM
