Got a P0341 code a few weeks ago. I replaced the cam sensor today, but I continue to get the code.
Symptoms are:
-Rough idle (Rougher than the typical XP idle)
-Occasional popping on decel (low rpm)
-Reduced MPG's
-Random Cruise KR (1* Max)
I can clear the code and it immediately shows back up as pending.
Watching the scanner, I don't see anything amiss in my scanned parameters.
I did check the wiring the best I could while changing the sensor and didn't notice anything obviously wrong.
Anyone else have any similar issue with a solution?
**NOTE** I have been having the cruise KR problem for a little while (few months) before I had this code pop up. I did, however, have two coolant elbow blow-outs within 8 days of each other shortly before this code appeared. (Not really sure if that caused anything, but I'm trying to provide as much info as possible here.)
