Thread: l32 2004 gtp. upgrading to a Q45 maf
Results 1 to 6 of 6
gtpsgofast l32 2004 gtp. upgrading to a... 02-04-2012, 12:48 AM
matt5112 Re: l32 2004 gtp. upgrading... 02-04-2012, 12:58 AM
gtpsgofast Re: l32 2004 gtp. upgrading... 02-04-2012, 10:32 AM
matt5112 Re: l32 2004 gtp. upgrading... 02-04-2012, 11:05 AM
gtpsgofast Re: l32 2004 gtp. upgrading... 02-05-2012, 09:11 AM
matt5112 Re: l32 2004 gtp. upgrading... 02-05-2012, 11:24 AM
  1. #1 l32 2004 gtp. upgrading to a Q45 maf
    Jan 2012
    Pennsylvania
    So the Q45 maf is a 85mm maf correct? I don't know about other years but my 04 has quite a large plug that goes into my stock maf. The photo that they show on zzp seems like there is no way that it can hook up even with the adapter plugs that they show. Have any of you guys with a 04 upgraded to the q45?
  2. #2 Re: l32 2004 gtp. upgrading to a Q45 maf
    Q45 as in infiniti Q45?
    Typically we go for the N*/LS6/LS1 MAF sensor.
  3. #3 Re: l32 2004 gtp. upgrading to a Q45 maf
    Jan 2012
    Pennsylvania
    N*/LS6/LS1 MAF sensor. So this would then be the LQ4? I'm reading that there are a 3pin and a 5pin hook up. Are these both 85mm?
  4. #4 Re: l32 2004 gtp. upgrading to a Q45 maf
    Five pin is preferred.
    Simply means the IAT is in the maf housing.
    If you were running an intercooler you might want to run your iat from the Lim instead.
    Check the part numbers, they're all probably the same.
    As for the size, I'm unsure.
  5. #5 Re: l32 2004 gtp. upgrading to a Q45 maf
    Jan 2012
    Pennsylvania
    I didn't know that. Fact is I'm getting ready for a I/C install real soon and thats why I was asking questions about upgrading my maf. So instead of having a iat in the maf your saying I could just tap into the lim because it would be cooler after the I/C ?
  6. #6 Re: l32 2004 gtp. upgrading to a Q45 maf
    No, itll probably be higher but its more accurate.
  1. Upgrading Brakes
    By Remnant King in forum Brakes/Suspension/Chassis
    Last Post: 04-21-2011, 11:15 PM
  2. PCM upgrading understanding
    By Lukus in forum PCM Tuning
    Last Post: 09-24-2010, 02:33 PM
  3. Upgrading my alternator
    By GAFF in forum Audio, Security & Visual Electronics
    Last Post: 01-17-2010, 05:12 PM
  4. Upgrading to 3.29 Gears
    By scottmmckinney in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-05-2009, 10:14 PM
  5. Fan Upgrading...
    By JoshMcMadMac in forum General Tech Discussion
    Last Post: 08-16-2008, 08:42 AM
