Thread: Supercharger question
Results 1 to 17 of 17
  1. #1 Supercharger question
    SE Level Member Compg4me's Avatar
    Dec 2011
    Grand rapids Mi
    So I was wondering if anybody could tell me how to tell the difference between a bad supercharger coupler and bad snout bearings. I have a noise coming from the snout at idle but it almost sounds like its coming from the center of the snout.
  2. #2 Re: Supercharger question
    Bastard Reptile's Avatar
    Kansas City, MO
    Remove the belt, and rotate the pulley back and forth. If it has play in it as you're turning it it's the coupler. Snout bearings will not have a smooth rotation to them, and they will usually start to squeal.
    Dec 2011
    Grand rapids Mi
    Here is a little video with the noise. You have to listen closely over the intake.
    http://www.youtube.com/watch?v=jA_MH...e_gdata_player
  4. #4 Re: Supercharger question
    here is vid on how to change that coupler. take the belt off and check for play, if so this is what you need to do.
    Replacing a worn out supercharger coupler on 3.8 GM engines - YouTube
    Dec 2011
    Grand rapids Mi
    So I took of the belt to feel for any play and I didn't notice any, also I noticed the noise tends to go away when the it gets to temp.
  6. #6 Re: Supercharger question
    do you have a cone filter? if so it may be normal, they all make noise till they warm up and with a open cone you can hear the engine better.
    Dec 2011
    Grand rapids Mi
    Yeah I do. I'll listen today to see if I notice it in the filter or not.
    Dec 2011
    Grand rapids Mi
    I don't hear the noise thru the filter. It's only by the snout.
    Dec 2011
    Grand rapids Mi
    I'm going to replace the coupler tomorrow. Does anyone know if I have to use Anaerobic sealant on the snout or can I use gm adhesive rtv?
  10. #10 Re: Supercharger question
    Charles City, IA
    anaerobic sealer is the correct they to use, I have not had one leak using the right stuff rtv tho.
    SMGPFC Two Nipple General
    Dec 2011
    Grand rapids Mi
    So rtv will work?
  12. #12 Re: Supercharger question
    anaerobic sealer is what you are supposed to use, i used hi heat black rtv, last year and im having no problems so far with it.
    Dec 2011
    Grand rapids Mi
    I'm going to give the rtv ultra black a try. It's high temp and ultra oil resistant. Should do the trick.
  14. #14 Re: Supercharger question
    you only need the smallest smear on the snout and housing there, dont glob it on, you dont want it to be squeezing out all over.
    Dec 2011
    Grand rapids Mi
    Does anybody know if the black Christmas tree plug in the end of the supercharger shaft is necessary? I tore mine up pretty bad and wasn't sure if I should order a new one.
  16. #16 Re: Supercharger question
    Kansas City, MO
    A necessity? not really, but it keeps crud out of the shaft, which is important because it acts as a vent.
    Dec 2011
    Grand rapids Mi
    I'll stop by zzp then and pick one up there super cheap anyways.
  1. supercharger question
    By shawnrandolph in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-15-2011, 11:00 AM
  2. new supercharger question
    By jersey jok3r in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2010, 09:49 AM
  3. Supercharger question
    By l3enner in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-29-2009, 09:39 PM
  4. Gen 3 Supercharger Question?????
    By gtpracer0186 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-19-2009, 10:02 PM
  5. supercharger question
    By bhrfpa11 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-02-2008, 02:34 PM
