Thread: 97-03 intake on an 04+ GP
Results 1 to 6 of 6
  1. #1 97-03 intake on an 04+ GP
    SE Level Member Keet04GTP's Avatar
    Jul 2008
    Tulsa
    Okay, so I want a cold air intake on my 04 GTP but the only one I like is the one at W-body store that fits the 97-03… It’s the mandrel bent tube that goes into the fender well. I know why it won’t fit… But what I was wondering was what everyone thought about cutting the tubing shorter to fit the 04 intake system placement… Any thoughts??
    2004 White GTP...Stock Stock Stock...Soon...3.0 ZZP MPS, ported blower, Pacesetter Coated Headers, FWI, Tuned PCM, VS cam, 105# springs, JP timing chain, whisper resonator and custom exhaust...My next goal(after I rebuild my savings)... 2.5" IC, 2.6 pulley, XPZ Cam, S3 heads, and a tranny....
  2. #2 Re: 97-03 intake on an 04+ GP
    Donating Users blowfishRus6's Avatar
    g.a.
    you gotta cut a place in it also for the MAF. 03 and older dident have them seprate like us. i like the design of that one too but i wasent sure about hacking it all up
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  3. #3 Re: 97-03 intake on an 04+ GP
    Jul 2008
    Tulsa
    Quote Originally Posted by blowfishRus6 View Post
    Yea, I wasn't sure about the cutting part... Everything looked the same as far as angle and such. I was thinking about cutting a section out for the MAF. I have a chop saw that will make clean cuts, so I'm not worried about that part of it... I guess I was just wondering if anyone knew if there is one out there that is identical to that one but with the MAF taken into consideration.
  4. #4 Re: 97-03 intake on an 04+ GP
    GT Level Member duane9586's Avatar
    Apr 2008
    ny
    make your own fwi. its not too bad to do..
    180*, Overkill, K&N, MSD, GEN V, AL 104's,ZZP Shift kit,SD Headers,1.9rr's, 90#,3.2zzp,0KR, 8K HID,Was a Base Model
  5. #5 Re: 97-03 intake on an 04+ GP
    g.a.
    yea cause idk if they make one for the 04+
    its slow.
  6. #6 Re: 97-03 intake on an 04+ GP
    Jul 2008
    Tulsa
    Well I'm probably going to buy some mandrel bent pieces and make a mock up for my buddy at the local exhaust shop to weld up. Then I'll have it powder coated...
  1. Intake Q
    By GTPJOE90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-03-2008, 02:35 PM
  2. intake
    By SahotaGTP in forum General Tech Discussion
    Last Post: 06-26-2008, 11:02 PM
  3. air intake ?
    By 59chevy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-04-2008, 03:43 PM
  4. Intake/??????
    By TMOTA503 in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-28-2008, 03:05 PM
  5. k&N Air intake
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-18-2008, 08:42 PM
