Thread: Injectors
Results 1 to 8 of 8
  1. #1 Injectors
    Nov 2011
    NY
    Ok, so I'm pulling my injectors off the rails to replace the o-rings while doing my LIM, SCSI, TB, etc job... And as I'm getting the o-ring off one if the injectors, the little plastic ring on the end of the injector snaps and breaks.
    So now, the question is, how important is the piece? Is it to just hold o-ring in place? Can it be ignored. Does anyone have a part#?
    Thanks for all advice, It's appreciated.
  2. #2 Re: Injectors
    The piece isn't important. You won't have any issues from that.
  3. #3 Re: Injectors
    Feb 2009
    flintnasty MI
    Most injectors do not use those little clips anyway. They are pretty handy though... I hate my 105# injectors without them.
  4. #4 Re: Injectors
    Nov 2011
    NY
    Cool, thanks for your replies, I thougt it'd be ok without it, just wanted to make sure.
  5. #5 Re: Injectors
    Nov 2011
    NY
    My apologies for asking another question...
    When putting everything back together today, I dropped and cannot find one of the Injector Clips into the engine bay.
    It's the wire type clip that locks the wiring connector to the injector, not the flat metal clip that holds the injector to the rail.
    I've looked all over the net and they're not listed anywhere. So, am I SOL, is it a big problem? I just worry that the connector could dislodge from the injector and that would be bad...
    I appreciate your help!
  6. #6 Re: Injectors
    Feb 2009
    flintnasty MI
    I had a EVO come into the shop without those metal clips on it... I ended up swaping some clips on from a spare connector.
    Stop by a junkyard and grab one.
  7. #7 Re: Injectors
    Texas
    ZZP stocks them, but you will have to contact them.
    85 Corvette
    01 TA
    03 Z06
  8. #8 Re: Injectors
    Nov 2011
    NY
    Quote Originally Posted by txslow6 View Post
    Thanks a million, and good news.
    I used two tiny Ty-wraps to hold it together as a safety thing for now. I just had another shipment from them go out yesterday, guess I should've thought to ask but didn't so thanks
  1. Injectors
    By saleenprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-15-2010, 03:47 PM
  2. l67 injectors
    By nascartech in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-08-2010, 08:56 PM
