good thing washer fluid is cheap as crap.
so now my question is, do you think I should run it on my car? my mods are all below... And where can i get the methanol from if i buy it?
its really up to you. its a knock reducer and allows you to maybe drop a pulley or two. you just have to be weary that if the pump ever fails or your fluid runs out when youre bombing your pedal to the floor then your knock is going to spike really bad.
2000GTP
IMO I don't really think you need it. It's for when you start to run into extreme applications. You could end up doing so much more before you will need a Methanol kit. In my case I'm running 3.0 and 2.8 pulleys, so I can definitely benefit from it more because it's a higher boost application.
