Thread: plug suggestion
Results 1 to 6 of 6
  1. #1 plug suggestion
    GT Level Member nicks98gtp's Avatar
    michigan
    Hey guys, Ive read through about every single spark plug post and I cant come to a solid conclusion. Recently I started getting a miss during WOT runs about midway through the powerband. It hasnt set any engine lights or anything but when the motor was built I put copper plugs in it which I hear go bad fairly quick. I just bought some Bosch Platinum plugs but after reading around on here Im not sure if i want to throw those in now. Im stock besides a ported S/C and an aftermarket PCM. Are the autolite 606's a decent plug at this point in time or is there something better out there? thanks in advance
    98 Gtp, ported s/c, fully rebuilt motor .20 oversized pistons, rebuilt trans, zzp pcm,more mods to come
  2. #2 Re: plug suggestion
    Omaha, NE
    You might be good on AL104s since you have bigger pisons.
  3. #3 Re: plug suggestion
    michigan
    the only downside is I dont have any way to scan the car right now so I dont want to try and get to cold of a plug or experiment around until im back to school. But food for thought thanks for the input
  4. #4 Re: plug suggestion
    michigan
    ended up going with the 606's and im satisfied so far. My miss is gone and it feels like i gained a little power back, the old plugs were pretty trashed but they were copper and had roughly 11k miles on them
  5. #5 Re: plug suggestion
    GTX Level Member cerick08GP's Avatar
    I’d say you made a good choice, you want to run the hottest plug you can. The closer to stock heat range the better IMO. Your tune might like the 605s better, you might want to check your KR sometime
    The 104s would come into play if you start changing pulleys.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  6. #6 Re: plug suggestion
    michigan
    ill be back in school tuesday so ill be able to scan again, but the smaller pulleys are coming lol. hopefully by next winter itll be where I want it to be
  1. stock antenna plug to universal plug?
    By kind153 in forum Audio, Security & Visual Electronics
    Last Post: 01-08-2012, 10:25 PM
  2. Rim suggestion..
    By joshsGT in forum Tires & Wheels
    Last Post: 03-31-2010, 06:33 PM
  3. Suggestion
    By Dohner in forum Forum Bugs/Suggestions
    Last Post: 02-08-2009, 04:19 PM
  4. Randomness .... Suggestion
    By Billyboi6 in forum Off Topic Discussion
    Last Post: 11-24-2008, 05:48 PM
  5. Another Forum Suggestion
    By TyroElite in forum Forum Bugs/Suggestions
    Last Post: 12-29-2007, 03:00 PM
