Thread: 1998 GTP TPS problem
Results 1 to 6 of 6
  1. #1 1998 GTP TPS problem
    Aug 2008
    Otoe, Nebraska
    ok i gotta 98 gtp...with a homeaid cai and 3.4" blower pulley...one day i was driving home after i left the city so it was at operation temperature...well when i floored it the service engine light came on....the car cut out past half throttle...and it kept cutting out...well i took it to oreilys and put it on auto xray and it said throttle position sensor/performance problem...so i ordered a new one and it still does the same thing...my dad tested both of them and they both are good and even with the new one on it still says its the TPS....when i put the cai i left the computer out in the open and strapped it down...i did that a month before this started happening...the book said that there is an open wire somewhere or faulty PCM....i cant figure it out because i dont have a diagnostic tool to read anything...does anyone have any ideas???? please help
    thanks
    kenneth
  2. #2 Re: 1998 GTP TPS problem
    SE Level Member JerzNick's Avatar
    Oct 2012
    New Jersey
    What's your diag tool? Can you see your LTFT's ?
    Bored block, Eagle Crank, XP Cam, Ported Heads/LIM/Blower/TB, 3.0 Pulley, CAI, Headers, 42.5#, AL 104's, etc...
  3. #3 Re: 1998 GTP TPS problem
    check the wires to the tps, they could be damaged, missing insulation or just cracks in the insulation will make it not work.
  4. #4 Re: 1998 GTP TPS problem
    St. Louis
    I'd bet he found it by now, seeing as it's from 08, and Last Activity 08-16-2008. Good info though.
  5. #5 Re: 1998 GTP TPS problem
    im gonna smack jerznick you dragged me into a dead thread........
  6. #6 Re: 1998 GTP TPS problem
    St. Louis
  1. worth it to buy? 1998 z24 auto convertibe
    By fst in forum Off Topic Discussion
    Last Post: 01-31-2008, 03:12 PM
  2. still got a problem
    By idriveamazda in forum 3.1L V6 (LHO/LG8)
    Last Post: 01-24-2008, 04:36 PM
