Thread: thought I should already know this by now... zzp pulley question
Results 1 to 10 of 10
  1. #1 thought I should already know this by now... zzp pulley question
    GTX Level Member Juanmiguel's Avatar
    Mexico
    Eversince I started dropping pulley sizes with the ZZP MPS, I've been setting the SC belt in the position which is further away from the SC, but after having a leaky snout seal, replacing the water pump and the harmonic balancer it got me thinking again if I'm putting the belt in the right position. Where should I be putting it? I've set it in the middle position of the 8 rib ZZP pulley for now. I don't remember which one would be the one that matches the original pulley's position.
  2. #2 Re: thought I should already know this by now... zzp pulley question
    Omaha, NE
    Depends on which position the belt fits best in. You want your belt to be as tight as possible to reduce belt slip.
  3. #3 Re: thought I should already know this by now... zzp pulley question
    GT Level Member jdmgtp's Avatar
    MI
    actually, you want to put it in the position that best aligns it with the rest of the pulleys in the system. Tension is controlled by the tensioner and belt size.
    2000 GTP, 3.2 pulley, SD headers, 3" exhaust, modded 1.9's, custom CAI, LS6 maf, ported blower/ TB, HPT, 65 lb injectors, E85 in the summer, LM-1 wideband, 180 stat, autolite 104's, GMHD suspension kit. 13.2@104 on street tires w/o ported s/c
  4. #4 Re: thought I should already know this by now... zzp pulley question
    Omaha, NE
    So, you should buy a pulley for ever .1 drop instead of moving the belt on the pulley?
    Sounds pricey.
  5. #5 Re: thought I should already know this by now... zzp pulley question
    what are you talking about?
    For the ZZP system you run in the middle.
    That aligns the belt best.
    results in most even wear.
  6. #6 Re: thought I should already know this by now... zzp pulley question
    MI
    Sounds pricey.
    wow
  7. #7 Re: thought I should already know this by now... zzp pulley question
    Charles City, IA
    The belt will move to where it wants to sit.
    SMGPFC Two Nipple General
  8. #8 Re: thought I should already know this by now... zzp pulley question
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    Sounds pricey.
    Quite sure trolling.
  9. #9 Re: thought I should already know this by now... zzp pulley question
    Mexico
    Ah yes i forgot to mention that having the belt in that position also resulted in it wearing off quickly on the side closest to the sc.
  10. #10 Re: thought I should already know this by now... zzp pulley question
    ZZP pulley systems, like Matt said sit in the middle. Intense sit on the innermost (towards TB) ribs.
    Very typically when I put a new belt on either, they like to jump one groove on the first start up. Fix it and it'll almost always stay where it belongs after that. Just an odd thing I've seen.
  1. 3.4 Pulley Question
    By samuelcb409 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-12-2011, 12:03 AM
  2. 3.4 Pulley Question
    Last Post: 10-01-2010, 09:32 AM
  3. S/C Pulley question
    By PMave in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-01-2009, 12:22 PM
  4. To Pulley or not to Pulley is not the question.... SIZE IS
    By massivesystem in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-27-2009, 10:43 AM
  5. pulley question
    By novmadman in forum General Tech Discussion
    Last Post: 02-08-2009, 07:05 PM
