Thread: geting exhaust downtube off
Results 1 to 17 of 17
  1. #1 geting exhaust downtube off
    Mar 2012
    michigan
    trying to get the exhaust down tube off ive sprayed it with wd40 tried to get a smaller socket 2 fit i dont have a torch and i think the bolt is close to striped due to rust any ideas on how else i am able to get this bolt off with out having heat for it again which i dont have
  2. #2 Re: geting exhaust downtube off
    Portland Oregon
    Are you talking about the upper side or lower side? If it's the upper side, put a 13mm socket on it with a long extension and hit it with an impact gun and hope it doesn't snap the bolt.
  3. #3 Re: geting exhaust downtube off
    Mar 2012
    michigan
    the lower when u lay under car and look up the exhaust has the nut on each side i got 1 off and other is striping or striped tried smaller sockerts no luck
  4. #4 Re: geting exhaust downtube off
    cut it drill it and tap it is about the only way if it's stripped.
  5. #5 Re: geting exhaust downtube off
    Mar 2012
    michigan
    i was hoping to not have to do that i dont have a torch i have all bolts out but this 1 and the motor is ready to pull
  6. #6 Re: geting exhaust downtube off
    Portland Oregon
    Are you dropping the motor out of the car on the cradle? If you're pulling it out the top you're messing with the wrong side of the downpipe. Just drop it with the exhaust if you're dropping it out the bottom. That way when it's out you can get better access at the bolt and maybe get it with a pipe wrench.
  7. #7 Re: geting exhaust downtube off
    Mar 2012
    michigan
    ok what bolts do i take out then i didnt think i had to pull the exhaust manifolds off to get engine out of the top billboost says get the ones underneith in the bak of the engine
  8. #8 Re: geting exhaust downtube off
    the ones that hook to the rear manifold 2 13mm bolts.
  9. #9 Re: geting exhaust downtube off
    Mar 2012
    michigan
    ya up under the car need a long extension to get to them possibly a swivvle socket
    13 is a little loose i got the first 1 with 13 and the second was rusted and wont budge
  10. #10 Re: geting exhaust downtube off
    Mar 2012
    michigan
    help?
  11. #11 Re: geting exhaust downtube off
    impact?
  12. #12 Re: geting exhaust downtube off
    Mar 2012
    michigan
    i can turn a 13 around the bolt by hand now its striped wats ur suggestion on cutting in small area
  13. #13 Re: geting exhaust downtube off
    you might end up having to pull the rear manifold. I had to on mine.
  14. #14 Re: geting exhaust downtube off
    Mar 2012
    michigan
    can i get it from under the car or above in the motor in the bak i could pull the motor forward some i think but idk if they are accessable
  15. #15 Re: geting exhaust downtube off
    I did mine from under the car.
  16. #16 Re: geting exhaust downtube off
    Mar 2012
    michigan
    got it off ever heard of easy outs? they are left threaded kinda and they cut into the metal they work get thanks autozone for 5 sockets for 25 dollars no return
  17. #17 Re: geting exhaust downtube off
    I have a set of those laying around for just such an occasion but i haven't used them yet to see if they are effective or not. At least now i know they are.
  1. 3.1 water coming from exhaust leak on exhaust manifold
    By ibhuff in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-21-2011, 01:54 PM
  2. Is it safe to drive with an Header exhaust leak or any exhaust leak??
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 05:45 PM
  3. Changing fluid, geting it all out
    By dagger in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-06-2009, 08:48 AM
  4. VRS EXHAUST- Mandrel Exhaust kit.
    By Lion29GTP in forum General Tech Discussion
    Last Post: 03-18-2009, 02:47 AM
