Thread: Cam design
Results 21 to 40 of 43
  1. #21 Re: Cam design
    Still rather incomplete.
    What you're suggesting is ensure the cam is properly degreed more than anything else?
  2. #22 Re: Cam design
    Which is the step most people skip...and even though tossing in the cam "works" in theory...you aren't getting the most out of it.
  3. #23 Re: Cam design
    Well its standard in any other platform, but we seem to skip right over it.
  4. #24 Re: Cam design
    what do you do differently to degree the cam? how many degrees can you push before you start knocking your valves?
  5. #25 Re: Cam design
    On the cam card you'll have valve timing, you're supposed to use a timing wheel to make sure the valve events occur at their specified time.
    If not, you have to use a timing set that allows you to advance or retard the cam to get it as close to the specified timing to ensure it performs as designed.
  6. #26 Re: Cam design
  7. #27 Re: Cam design
    Feb 2009
    flintnasty MI
    Not so much, just saying that even drastic swings in cam design never netted more than a few horsepower here or there... most of the time anything severe resulted in powerband loss like you would find in a TEP / IS4, without peak power gains more than a hp or 2.
    With the turbo stuff, we were making peak power around 4700rpms because the boost spiked up a bit.... otherwise it was flat across on our ST4/xpz stuff.
  8. #28 Re: Cam design
    Thanks for clarifying.
  9. #29 Re: Cam design
    GT Level Member RegalGS98s's Avatar
    NJ
    Meh, its not that there is much to explain by it. The heads are just overall restrictive, valve seat and port size is too small to justify more "length" in the valve opening. Also the valve angle is very shallow which does not promote flow at high lift like a steeper valve angle would.
    When force inducted you also run into issues of the intake not needing alot of lift to achieve the same results... Less valve lift and minimal ramp rate is going to give you better real world results by increasing your valvetrain accuracy on sub 150# springs.
    ZZP has been there and done the lift thing, its not worth it for power, so now they only sell cams with 550-580 total lift on stock rockers. I was out there in grand rapids when they put 3 different cams in the impala, and it was clear that lift only hurt things, while installation angle actually produced more WHP swings than any other thing we could do in the cam profile (for reasons unrelated to valvetrain I may add, but that is a different thread all together).
    So, there is your blanket response, any questions?
    I guess the .550-.580 lift is why ZZP doesn't seem too willing to set me up with their XPZ cam using 1.7 rollers. They told me it might bind using 3/8 pushrods, though on their site it says can be used with 1.7 rockers. I sent an email to Blue earlier about the XPZ cam card Matt and him were discussing, but I don't know if he received it with this new forum design.
    SMGPFC #0330 - 3.25, Intercooled, Custom Tune, 1.84rr, LS6 Springs, roller timing chain, SLP Headers, Borla Exhaust, built Trans, B&M Trans Cooler, home cut poly uppers, gapless rings, N* TB, Ported heads.
    Soontocome: CAM?, Custom modified M112, home poured Poly Engine and Trans mounts
  10. #30 Re: Cam design
    GT2 cam ftw?
    Ohio
    Gt2> all others you're saying?
    Well im looking for easy on valvetrain yet sound cool. Gt2 should fit that bill.
    Smaller than nic yet still quite a bit of overlap.
  13. #33 Re: Cam design
    moar lope.
  14. #34 Re: Cam design
    GT2 lift and morreeee separation...think, 108*?
    Gt2 is 111 lsa?
  16. #36 Re: Cam design
    110*, GT1 is 112* IIRC, but both have same peak lift?
    Odd.
    Want to see the gt2 and vs cam card?
  18. #38 Re: Cam design
    GT2 > VS.
    Already seen that mess.
    You get my pm?
    Im no longer entirely convinced.
    Still going to do it anyways.
  20. #40 Re: Cam design
    i like to know things. why not share it with all of us?
  1. LIM Gaskets: First and Second Design
    By BillBoost37 in forum How To Write-Ups/Tech Tips
    Last Post: 12-15-2010, 01:26 PM
  2. What Box Design for 02 Coupe
    By nicklbmx in forum Audio, Security & Visual Electronics
    Last Post: 05-24-2010, 08:28 PM
  3. whitcomb's design
    By nemesis in forum Visual/Body Modifications
    Last Post: 01-26-2010, 11:28 AM
  4. Sub box design
    By dagger in forum Audio, Security & Visual Electronics
    Last Post: 08-03-2009, 02:10 PM
  5. SRT Design
    By flash527 in forum Track Sessions and Kills
    Last Post: 07-22-2009, 06:27 AM
