Thread: Clamps on air intake
Results 1 to 14 of 14
GTP in RTP Clamps on air intake 12-27-2011, 10:12 PM
Explicit_Spade Re: Clamps on air intake 12-27-2011, 10:14 PM
GTP in RTP Re: Clamps on air intake 12-27-2011, 11:23 PM
TheOtherNick Re: Clamps on air intake 12-27-2011, 11:30 PM
Explicit_Spade Re: Clamps on air intake 12-27-2011, 11:33 PM
TheOtherNick Re: Clamps on air intake 12-27-2011, 11:34 PM
GTP in RTP Re: Clamps on air intake 12-27-2011, 11:42 PM
Z34Phoenix Re: Clamps on air intake 12-28-2011, 08:23 AM
GTP in RTP Re: Clamps on air intake 12-28-2011, 08:32 PM
blueguy Re: Clamps on air intake 12-30-2011, 04:10 PM
GTP in RTP Re: Clamps on air intake 12-30-2011, 07:46 PM
blueguy Re: Clamps on air intake 12-31-2011, 11:02 AM
GTP in RTP Re: Clamps on air intake 12-31-2011, 11:51 AM
blueguy Re: Clamps on air intake 12-31-2011, 12:07 PM
  1. #1 Clamps on air intake
    GTP Level Member
    Oct 2011
    Raleigh, NC
    Should there be two clamps on my air intake hose ? I have stock hose with the one clamp at airbox with thumbscrew.
    The otb end just slips on, should there be another worm clamp ?
    1997 Red GTP 182000 miles stock
  2. #2 Re: Clamps on air intake
    Omaha, NE
    Yep. One on each end of the tubing.
  3. #3 Re: Clamps on air intake
    GTP Level Member
    Oct 2011
    Raleigh, NC
    That's what I thought, probably my vac leak causing p0171.
    Is it 4 inch ?
    Thanks
  4. #4 Re: Clamps on air intake
    Charles City, IA
    No clamp on the tb side.
    SMGPFC Two Nipple General
  5. #5 Re: Clamps on air intake
    Omaha, NE
    I didn't read 97, Nick is correct.
  6. #6 Re: Clamps on air intake
    Charles City, IA
    Im always right.
  7. #7 Re: Clamps on air intake
    GTP Level Member
    Oct 2011
    Raleigh, NC
    Quote Originally Posted by TheOtherNick View Post
    Im always right.
    ok, no tb clamp.
    Back to changing vac lines, any idea on the size of the small hoses ? are they all mostly one diameter ?
  8. #8 Re: Clamps on air intake
    Florida
    IIRC they are 1/8" inner dia. if you are replacing with aftermarket vac hose it should be fine as along as it they fit on the vac ports. im planning to remove most of the stock plastic vac lines and run either rubber vac line or bend metal line! think it would look cool and last much longer.
  9. #9 Re: Clamps on air intake
    GTP Level Member
    Oct 2011
    Raleigh, NC
    Quote Originally Posted by Z34Phoenix View Post
    I hate the plastic lines, break too easy. Going to replace all with vac hose to try to stop P0171.
    I notice everyone talks about the "Tee under the sc snout" ,mine just has an elbow and one line ? Is this normal for a '97 ?
    Stupid question I know, but previous owner had other hoses messed up and i am checking everything.
    thanks
  10. #10 Re: Clamps on air intake
    To answer...yes the '97's are year specific for vac line routing...
    '97 GTP Vac. Diagram...
    '98-'03 GTP Vac. Diagram...
  11. #11 Re: Clamps on air intake
    GTP Level Member
    Oct 2011
    Raleigh, NC
    I found the vac routing sticker, mine does not show the line to the trans ?
  12. #12 Re: Clamps on air intake
    Now that I look at it...it might be to a previous-gen car that had a 4T60-E vac. transmission...so don't worry about that line...you have the 4T65E-HD...no vacuum lines needed
  13. #13 Re: Clamps on air intake
    GTP Level Member
    Oct 2011
    Raleigh, NC
    Thanks, that what I thought.
    I just need to replace the hose, previous owner had it rigged up badly. Is there a reducer on the tb that takes the size down to match the purge valve ?
    I assume that would be the correct way, prev owner has big hose with an adapter connected to the smaller hose.
  14. #14 Re: Clamps on air intake
    Maybe take a picture and post it...since you seem to have something we'd actually have to see to correct it?
  1. Torca exhaust clamps, yo.
    By SDGTP99 in forum General Tech Discussion
    Last Post: 07-11-2011, 07:56 PM
  2. header gasket - header clamps - kn filter
    By homerunhitter629 in forum General Tech Discussion
    Last Post: 02-21-2011, 10:00 AM
  3. What Size Torca Clamps For SSAC Headers?
    By AmericanRiceEater in forum General Tech Discussion
    Last Post: 06-18-2010, 11:54 AM
  4. trans cooler with hose clamps FTL!!!!
    By gtpinsc in forum Off Topic Discussion
    Last Post: 12-24-2009, 03:10 PM
