Thread: should my idler pulley on S/C spins so easy?
Results 1 to 7 of 7
  1. #1 should my idler pulley on S/C spins so easy?
    Dec 2011
    mankato minnesota
    the front most pulley for the s/c spins really easy sounds like a roller skate wheel when i spin it. is it shot? should it be replaced or is this normal putting new belts on today and noticed it
  2. #2 Re: should my idler pulley on S/C spins so easy?
    it should spin easy it's an idler pulley there should be no drag on it at all other than the bearings.
  3. #3 Re: should my idler pulley on S/C spins so easy?
    Omaha, NE
    Spinning is good. The faster ilders spin, the better.
  4. #4 Re: should my idler pulley on S/C spins so easy?
    Feb 2008
    Sounds normal to me. It is made to spin freely. Why do you think it should have resistance?
  5. #5 Re: should my idler pulley on S/C spins so easy?
    Antioch, IL
    should not make any noise. mine did and 10k miles later it sheared off while driving. Cost me $15 to get a replacement.
    2009 Challenger SRT8
    Expert at being gay.
  6. #6 Re: should my idler pulley on S/C spins so easy?
    Dec 2011
    mankato minnesota
    i just wasnt sure if it was suppose to spin that freely thought there was suppose to some resistance but its normal from what you guys have said
  7. #7 Re: should my idler pulley on S/C spins so easy?
    GT Level Member RegalGS98s's Avatar
    NJ
    I know this is a little late, but if it sounds like a roller skate wheel spinning (with the little rattle they make), it's probably lost it's grease and that's why it spins more easily. I would replace it, they're pretty cheap.
    SMGPFC #0330 - 3.25, Intercooled, Custom Tune, 1.84rr, LS6 Springs, roller timing chain, SLP Headers, Borla Exhaust, built Trans, B&M Trans Cooler, home cut poly uppers, gapless rings, N* TB, Ported heads.
    Soontocome: CAM?, Custom modified M112, home poured Poly Engine and Trans mounts
  1. Lower idler pulley
    By tapuout2 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-13-2011, 08:33 PM
  2. Idler Pulley Bolt
    By pmanchin in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-14-2010, 02:57 PM
  3. idler pulley question
    By 99grandprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-26-2010, 10:02 AM
  4. Idler pulley really loose
    By Lionel in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-24-2010, 03:27 PM
  5. Idler&tensioner pulley help
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 01-15-2010, 10:36 AM
