Thread: urgent need help misfire
Results 21 to 40 of 59
  1. #21 Re: urgent need help misfire
    GT Level Member gtcoup's Avatar
    Dec 2010
    plymouth ma
    acdelco's, not sure exact ones, assuming stock. the plug wires are aftermarket too. the guy claimed to have had replaced them 3k ago...
    Smgpfc
  2. #22 Re: urgent need help misfire
    Iridium or platinum?
    What el cheapo wires you got?
  3. #23 Re: urgent need help misfire
    Dec 2010
    plymouth ma
    wires are "belden edge" 7mm wires. i compared resitance between the wires on my gt and the gtp, there about the same resistance. not sure about plugs. its pouring i just got soaked checkin wires
    Smgpfc
  4. #24 Re: urgent need help misfire
    SE Level Member Hixc's Avatar
    Lawrence MA
    Bill lives in Enfield CT, im sure he could diagnose it for you if you get it to him, i see you are from mass. Sounds like either the o2 sensor is out of range at wot or a bad fuel injector. is the car completely stock?
    S1X, TOG, Trannyman Gen3, 3.0/2.8, 42.5#, 105#, Thrasher, Borla PRO XS, Magnaflow Cat, 1.6 roller rocker
  5. #25 Re: urgent need help misfire
    Dec 2010
    plymouth ma
    as far as i know its stock.
    Smgpfc
  6. #26 Re: urgent need help misfire
    Dec 2010
    plymouth ma
    ideas people?
    Smgpfc
  7. #27 Re: urgent need help misfire
    when it stops rainin..oh ..hey it has. Go check those plugs
  8. #28 Re: urgent need help misfire
    Dec 2010
    plymouth ma
    plugs are acdelco 4 -101 i think
    Smgpfc
  9. #29 Re: urgent need help misfire
    Dec 2010
    plymouth ma
    crappy droid pic
    Smgpfc
  10. #30 Re: urgent need help misfire
    41-101 are iridiums. Shouldn't be a problem. Unless you pull that cylinder and see something directly shorting the tab to the center. I'v ehad that happen on a couple ATVs in the past.
  11. #31 Re: urgent need help misfire
    Dec 2010
    plymouth ma
    so what should I do now/ where should I look for issue
    Smgpfc
  12. #32 Re: urgent need help misfire
    Probably in Enfield CT
  13. #33 Re: urgent need help misfire
    Dec 2010
    plymouth ma
    whatcha think? burnt valve? bad head?
    should i do a compression test?
    Smgpfc
  14. #34 Re: urgent need help misfire
    Dec 2010
    plymouth ma
    i also forgot to metion it only does it when im heavy on the throttle but when i was light just gettin up to speed i did not notice a missfire. i drove for an hour on the highway and the last like 2 miles from home i layed on it and thats when it misfired/
    Smgpfc
  15. #35 Re: urgent need help misfire
    Dec 2010
    plymouth ma
    so i did a compression test. cylinder 6 and 3 both show 165 psi. what gives? im completely cluelesss as to where else to look
    Smgpfc
  16. #36 Re: urgent need help misfire
    bg ky
    have you checked the injector to see if its connected or maybe bad ?
  17. #37 Re: urgent need help misfire
    Your compression is fine.. totally normal.
    I'd be looking at the coils to see if you have a weak one.
  18. #38 Re: urgent need help misfire
    Dec 2010
    plymouth ma
    i took the coil from my gt and threw it on and it still missed
    Smgpfc
  19. #39 Re: urgent need help misfire
    Dec 2010
    plymouth ma
    so would driving it right now be bad? im dying to put it on the road its killin me lookin at it. and i have a few people interested in the gt
    Smgpfc
  20. #40 Re: urgent need help misfire
    Probably time to look in the cylinder with a borescope.
  1. Urgent!! Will @ overkill
    By f3racer in forum PCM Tuning
    Last Post: 05-13-2011, 09:38 AM
  2. Urgent read ! Oil oil oil>
    By AmericanRiceEater in forum General Tech Discussion
    Last Post: 06-04-2010, 12:43 PM
  3. Urgent help
    By milfadic in forum General Tech Discussion
    Last Post: 05-20-2010, 06:02 PM
  4. urgent dead car
    By Sunstone in forum General Tech Discussion
    Last Post: 09-07-2008, 12:22 PM
  5. Urgent need of Help
    By Sunstone in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-31-2008, 01:22 PM
