Thread: 99 gtp starts and dies..
Results 1 to 3 of 3
  1. #1 99 gtp starts and dies..
    Aug 2011
    alton
    Hello, we had a 99 gtp towed in today, just died. Any way it will start and die, start and die unles we give it throtle. First we noticed the SC belt and idler pully was gone. But customer said its been running like that. So we did a fuel psi text. with key on gauge shows 55psi, Then when it fires up drops to approx 45 then the gauge drops stedly to zero and dies at approx 15psi. Humm so we did the cheap changed filter, no good same reading, checked psi reg seemed ok but we changed it, same readings.. so humm fuel pump thats all thats left right.. so we had a good one. Changed it over and still same syptoms, 55 with key on then 45 under crank, then when it start the psi stedly drops to zero.. car dies. not if i chasing my tail,barking up wrong tree or what.. any ideas?
    Thanks
    BTW the iac,tp,map and mas have been changed.. with no change.. its like the fuel pump stops.. we also changed the relay..
  2. #2 Re: 99 gtp starts and dies..
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    same thing i said on other thread.....try to only post in one area. mods will delete one of these probably.
    1997 Grand prix GT Black Coupe- The beater
    1998 Grand prix GT Black coupe- Top swapped, XP cam
    2008 Grand prix Midnight blue- The slow but nice car
    1999 Chevrolet Silverado red ext. Cab
  3. #3 Re: 99 gtp starts and dies..
    GT Level Member nicks98gtp's Avatar
    michigan
    possibly the fuel pump resistor went out? Mine had the same symptoms when mine went, the car just died while driving, then it would restart, stutter and die after a few seconds without throttle keeping it alive.
    98 Gtp, ported s/c, fully rebuilt motor .20 oversized pistons, rebuilt trans, zzp pcm,more mods to come
  1. Car starts then dies
    By Rocket468 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-15-2011, 01:08 AM
  2. Starts then Dies!
    By 1999GTP1999 in forum General Tech Discussion
    Last Post: 01-29-2010, 08:42 AM
  3. starts and dies
    By betsgtp in forum General Tech Discussion
    Last Post: 11-30-2009, 08:56 AM
  4. 04 starts then dies
    By oldtruckluvr in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-06-2009, 08:09 PM
  5. HELP: Starts then dies after LIM
    By rfmgtp02 in forum General Tech Discussion
    Last Post: 06-23-2009, 03:35 PM
