Thread: Leaking Oil!?
Results 1 to 10 of 10
  1. #1 Leaking Oil!?
    SE Level Member illtacticz's Avatar
    Dec 2010
    Columbus, Ohio
    Back Story:I was driving home from Florida to Ohio in my 2000 GTP and I began to smell a faint exhaust type oil smell. I pulled over at the gas station looked under the car and noticed oil leaking from the car. First off I thought the nut from the oil pan wasn't tightend, because I got an oil change before leaving for Ohio. But I wasn't sure. Seeing that it was only dripping a little bit I checked the oil level which was full, kept going and made it to Florida with no problems.
    I took it back to the place that did the oil change to make sure everything was tightend properly and they told me my Oil Sending Unit was bad. I picked one up from Auto Zone for about 13.00 bucks, but where the heck does it go!? Is it an easy fix, or should I call my mechanic?
  2. #2 Re: Leaking Oil!?
    look at the oil filter, on the neck, they is a sensor on the back side, remove the old one, install new one with teflon tape or thread sealer.
    Oil will come out, so have something to catch it, and refill when done.
    ps. take teh pass side tire off, makes it easy.
  3. #3 Re: Leaking Oil!?
    Doesn't get better than that ^^ for a how to on this puppy.
    Unless you haz pictures!
  4. #4 Re: Leaking Oil!?
    Dec 2010
    Columbus, Ohio
    Cool, thanks!! Off hand, do yall know what size socket the OSU takes?
  5. #5 Re: Leaking Oil!?
    you wont be able to get a socket on it, use an open ended wrench, its big maybe 21mm or 7'8th
  6. #6 Re: Leaking Oil!?
    Dec 2010
    Columbus, Ohio
    Okay heading out to do it right now... I picked up a 27 socket, guy at Autozone ensured me it would work... we shall see...
  7. #7 Re: Leaking Oil!?
    Typically you can ...in theory use a socket if you can swing the ratchet. Sometimes a short extension and the ratchet coming down behind the CV will do the trick. It's possible, just tight.
  8. #8 Re: Leaking Oil!?
    Dec 2010
    Columbus, Ohio
    All done..easy fix. And I was able to use the socket, had to work it around in there a little bit, but It was cool. 20 minute job, no prob!
    Thanks for the feedback...
  9. #9 Re: Leaking Oil!?
    20 minutes? i did 3 of them in 10 or less, used a channel lock as nothing really fits well in there, after blowing 3 of them, i now have a brass plug in the hole where the sensor used to be,oil pressure gauge to follow as next install.
    brass plug 2 bucks, not buying another crappy sensor. both the autozone and pepboys sensor failed me, all with in a year, keep an eye on the new one.
  10. #10 Re: Leaking Oil!?
    Donating Users crock's Avatar
    Traverse City, Michigan
    Bill seems to always be on the ball!
    99 GTP- 104s, 180 Tstat, 1.9 rockers, 3.4, ls1 MAF, KN, 3''DP, HF cat, GMPP Strut Bars, Crappy Tune, Broken Tensioner Mod.
  1. Leaking A Little Oil...
    By develand in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-21-2011, 02:35 AM
  2. leaking pan
    By tdm571 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-01-2011, 03:18 PM
  3. Leaking Oil ?
    By Blacknight02GT in forum General Tech Discussion
    Last Post: 12-30-2010, 11:29 AM
  4. leaking air
    By nyydmb12 in forum Tires & Wheels
    Last Post: 07-14-2009, 07:39 AM
  5. S/C Leaking???
    By jagamite in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-02-2008, 08:53 PM
