Thread: Weird Wistling
Results 1 to 17 of 17
  1. #1 Weird Wistling
    Donating Users crock's Avatar
    Traverse City, Michigan
    Ok, this may sound weird. When I am accelerating with my music turned down and heat off, there is a whistling/ humming on the inside of the car. I am not sure what it is. I can tell you that my heat feels like it is on, but it is not. I just want to stop the annoying humming and the possibility that the heat is on. I can feel the warm on my legs. So my question is what may be causing this hum/ whistle? I do have my car ran for subs, so the little rubber fitting in the firewall is out. Could the heat be coming from there? Thanks guys. Help me! Its not major.... just annoying...
    99 GTP- 104s, 180 Tstat, 1.9 rockers, 3.4, ls1 MAF, KN, 3''DP, HF cat, GMPP Strut Bars, Crappy Tune, Broken Tensioner Mod.
  2. #2 Re: Weird Wistling
    Out West
    Maybe it's your sc.
    Whine with your Cheese?
  3. #3 Re: Weird Wistling
    Im not retarded. Lol. I know the difference. When I put it in boost, you can tell the difference. The interior is whistling, not the supercharger...
  4. #4 Re: Weird Wistling
    Out West
    maybe you have a secret turbo.
  5. #5 Re: Weird Wistling
    Arg! Yes I am a pirate. I just want help! Not saying that I have a turbo... Cause I dont. I own the slowest GTP in the world.
  6. #6 Re: Weird Wistling
    Out West
    Not evenz a lil one?
  7. #7 Re: Weird Wistling
    Wow. No. I just want help. There is no turbo. I would know... Trust me.
  8. #8 Re: Weird Wistling
    SE Level Member jaked1985's Avatar
    Jan 2012
    West Union, Iowa, United States
    Mine did that too... less noticeable after open cone intake..
  9. #9 Re: Weird Wistling
    Pennsylvania
    Put your ear up next to the blower under the glovebox. My aftermarket one whistles when only turned up a single notch. Maybe yours is getting an itty ibtty dash of power and it's spinning.
    Or you have a vacuum leak.
  10. #10 Re: Weird Wistling
    Im pretty sure I dont have a vacuum leak. I might have a bad blower motor... But it even does it when it is off....
  11. #11 Re: Weird Wistling
    Howell, NJ
    Where did you run your power line for the subs?
  12. #12 Re: Weird Wistling
    through the rubber fitting... but I took it out today and put the fitting back in.
  13. #13 Re: Weird Wistling
    The dark side of the Moon
    could be the turbro muffler whistle.
  14. #14 Re: Weird Wistling
    SE Level Member dert's Avatar
    Jul 2011
    Big Rapids, MI
    I have/had this problem too. I never figured out what it was but it went away and randomly comes back for a couple minutes. Sounds like almost the old radios did in cars from electrical interference in mine. but radio is off and its not coming from the speakers. and its quiet kinda? ide like to know if anybody finds out what it is too if ours is the same thing..
  15. #15 Re: Weird Wistling
    It is exactly like that. It will go away from time to time, but come back later. I thought it was from the speakers on day, but it wasnt.
  16. #16 Re: Weird Wistling
    Howell, NJ
    When drilling through the rubber fitting you may have clipped the vacuum hose there. I did the same thing when installing my subs.
    http://www.grandprixforums.net/help-...all-57607.html
  17. #17 Re: Weird Wistling
    I never drilled through my fire wall.... all i did was remove the rubber fitting. thats it.... Im not mechanically retarded. I wont drill through a hose...
  1. weird DTC...
    By Viper in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-17-2010, 12:33 AM
  2. weird....
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 05-24-2010, 12:30 AM
  3. 98 Gp odd wistling sound
    By ph1zh in forum General Tech Discussion
    Last Post: 04-11-2010, 09:41 PM
  4. weird that my car is doing this!!!!!
    By lilredss0287 in forum Turbo
    Last Post: 12-05-2008, 04:59 AM
  5. weird...
    Last Post: 10-15-2008, 10:56 PM
