Thread: Opinions on N* TB please
Results 1 to 18 of 18
  1. #1 Opinions on N* TB please
    SE Level Member wpbboy81's Avatar
    Sep 2011
    west palm beach, fl
    Im torn as to whether i want to get a N* setup or not. I want to, but i keep reading about ppl not liking the throttle feel of them and saying its not worth it. What exactly is the difference in throttle feel? I thought it gave a better response time?
    98 GTP, VS cam, SD headers, 3" full exhaust (cat/resonator/ubend deleted), genV blower, 3.4 MPS, ported LIM, open cone air filter, custom tune, alternator power cable, fuel pump rewire, AL 104s, 180 stat, flipped dog bones, 04 GTP front rotors w/ F-body calipers, and the oh so comfortable monte carlo seats
  2. #2 Re: Opinions on N* TB please
    I'm one of the lovers.
    However..I can explain the feel to you pretty well. An L67 TB has a 1/4 of a circle as the throttle plate tip in actuator. (look at side with cable). It's pretty straightforwarrd. Now a N* starts off gentle and blammo.. it goes straight down.
    This gives you nice low throttle ability and then....holy mother of power. Plus..it's a larger bore and could potentially gulp more air.
    N*
  3. #3 Re: Opinions on N* TB please
    Sep 2011
    west palm beach, fl
    Oh, so besides it being bigger and getting more air in, it opens up wider with less throttle effort?
  4. #4 Re: Opinions on N* TB please
    Florida
    here is another reason for me to swap then. the progression of the TB on the Northstar is closer to the DOHC's TB. the compound linkage on the 3800 is just weird to me
  5. #5 Re: Opinions on N* TB please
    i never liked the throttle feel of the northstar so i only ran it for a week before i went back to a ported stocker. i just couldnt stand how you'd barely touch the pedal and the car would be into boost already.
  6. #6 Re: Opinions on N* TB please
    Houston
    What...you mean like when you stop to go over a speed bump real slow and you give it a little bit of gas to get over it and you end up ramping the fugger? Yeah, I haz that problem.
  7. #7 Re: Opinions on N* TB please
    its just too soft feeling. you need that little resistance to know where the pedal actually is.
  8. #8 Re: Opinions on N* TB please
    Houston
    It took me a long time to figure out how take off normally, without spinning the tires. It was a lot different than the other 2 gp's that I had.
  9. #9 Re: Opinions on N* TB please
    Sep 2011
    west palm beach, fl
    yea i guess that would be kind of a bother especially if ur trying to just cruise. is a good prted TB just as good as a N*?
  10. #10 Re: Opinions on N* TB please
    Buffalo
    It's not soo dramatic. You will get used to it. You can drive normally between 1-20% tps all day then really push it in for wot.
    I noticed on mine, by reading my vcm scanner, that I can push down to almost 60% tps until it hits that "wall" then any more And your on your way to wot!
    I love it.
    And here's to the haters of the N*, they didn't mention your cai no longer sounds like a fire-breathing monster at start up anymore
  11. #11 Re: Opinions on N* TB please
    Bunnell, FL
    ^^^ does it still sound like a broken vacuum cleaner?
    and bill sold me on a n*
    I'm a Sex Offender
  12. #12 Re: Opinions on N* TB please
    Sep 2011
    west palm beach, fl
    yeah, im pretty much sold on it too. if the only problem pple dont like about it is it being too touchy, thats not a big deal for me....or at least i hope it wont be.
  13. #13 Re: Opinions on N* TB please
    Florida
    come on with 2.92's it should be fine. with 3.29's i have it would be even touchier and i'd feel bad for people with the 3.69's! i know when i had the DOHC with the 3.73's it was very easy to spin up the tires. then again im running 245/45-17's which are much smaller then the stock tire dia. i ran the numbers once and it would be like running a 4.10 ratio on a stock tire. with those gears i could edge out a stock GTP off the line then when the engines power band kicked in at 4300 rpm i would be gone.
    the only thing i didnt like about the 3.73's is my HW milage took a hit. lost about 3mpg on the highway. but around town since i could ride 4th at 38 mph i was doing ok.
    One other Thing i like about the north star is that it is shorter then the stock TB. this will give me more space to make my intake as on my monte the engine bay is narrower.
  14. #14 Re: Opinions on N* TB please
    The only reason I didnt like it is that you had to be REAL good at launching it or you spin (which I kinda got used to until winter came around...snow+torque+touchy throttle= NO traction)...
    I haven looked back since I switched to a LS1...
  15. #15 Re: Opinions on N* TB please
    Quote Originally Posted by gtpsleeper View Post
    FINALLY.
    This guy pulls through.
  16. #16 Re: Opinions on N* TB please
    FINALLY.
    I have my moments
  17. #17 Re: Opinions on N* TB please
    GTP Level Member
    Nov 2008
    MA
    arent there issues with the maf when tuning the ls1 tb though?
    03 GTP - 13.8 @ 100 2.160ft
    99 GTP - DD
    *Operation Iraqi Freedom/Operation New Dawn Veteran*
  18. #18 Re: Opinions on N* TB please
    I haven had any... probably depends on what maf setup you run though...
    now that im thinking about it, it was actually easier to tune after the swap do to the fact that the LS1 wasn as touchy... made it easier to hit more cells (thats personal though idk about anyone elses experiences) so I could dial it in better...
  1. Need Opinions
    By BwolfGT in forum Off Topic Discussion
    Last Post: 03-28-2010, 09:53 AM
  2. opinions
    By TorqueAutoMotiv in forum Tires & Wheels
    Last Post: 03-26-2010, 12:25 PM
  3. opinions please
    By 99prixgt in forum Tires & Wheels
    Last Post: 11-05-2009, 11:41 AM
  4. Need opinions
    By 1998xGTP in forum Off Topic Discussion
    Last Post: 02-18-2009, 04:54 PM
  5. What you think about this GTP, please opinions
    By robahr24 in forum Off Topic Discussion
    Last Post: 02-06-2009, 12:34 PM
