Thread: Rubber "T" Fitting Question
Results 1 to 7 of 7
  1. #1 Rubber "T" Fitting Question
    OHIO
    I need a part number for the the rubber connector T thats right under the snout of super charger. 2000 GTP. I believe its for my boost indicator.
  2. #2 Re: T
    Check the local junkyards for some...I always yank them off cars when I'm there for this reason...
    You can go to your local dealer and tell them to pull up a diagram of the motor and you can get the entire section but I don't think you can just buy the "T"s seperatly.
  3. #3 Re: Rubber "T" Fitting Question
    OHIO
    I checked with the dealer and you have to buy both lines for fifty bucks. I was trying to find it on line and forgot to write the part number down.
  4. #4 Re: Rubber "T" Fitting Question
    I'd just go up there and have them pull the diagram again and write down the part # just for the "T" then...like I said...do you have any junkyards local to you?
    Check them as well.
  5. #5 Re: Rubber "T" Fitting Question
    OHIO
    thanks, I'll check the junk yards
  6. #6 Re: Rubber "T" Fitting Question
    SE Level Member logan809's Avatar
    Sep 2011
    Kansas
    I redid all my vacuum lines with napa tee fittings and vacuum hose. Something like 50 cents a foot for line and 2-3 bucks for the tees
    1997 Grand Prix GTP
    Ported Gen 3, Ported TB, FWI
  7. #7 Re: Rubber "T" Fitting Question
    Windsor (ON) Canada
    Quote Originally Posted by logan809 View Post
    I'm going to go with THIS^^. I had to make one up (the dealership felt bad for me... that's right!! and gave me a foot of hose for free) I bought a barbed T and made one up.. Ill snap a pic if you want.
    Ps...ya, the you can't buy the T seperate from the dealership (I tried too). Haven't seen a S/C'd GP in my local yard yet, hence why I had to make my own.
  1. which fitting is which?????
    By chancinit666 in forum General Tech Discussion
    Last Post: 12-11-2010, 11:58 AM
  2. where to get rubber t's for vac lines
    By e6600 in forum General Tech Discussion
    Last Post: 05-01-2010, 10:09 PM
  3. FPR vac fitting
    By Sabrewings in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-08-2009, 11:50 PM
  4. new rubber on
    By QwikGT in forum Visual/Body Modifications
    Last Post: 08-02-2008, 06:25 PM
