Thread: Should my valvetrain be ok for an S1X cam?
Results 21 to 40 of 66
  1. #21 Re: Should my valvetrain be ok for an S1X cam?
    Why not have it nitrated after having it machined?
  2. #22 Re: Should my valvetrain be ok for an S1X cam?
    SE Level Member Hixc's Avatar
    Lawrence MA
    Bill is in the process with my S1X install, i'll let you know how it goes. Basically 1.6roller rocker, intense or pushrods, lifters, 105#springs, retainers, locks and viton valve seals(.020) extra clearance. using rollermaster single chain and dampener.
    S1X, TOG, Trannyman Gen3, 3.0/2.8, 42.5#, 105#, Thrasher, Borla PRO XS, Magnaflow Cat, 1.6 roller rocker
  3. #23 Re: Should my valvetrain be ok for an S1X cam?
    Buffalo
    Sounds good. I couldn't trade my 1.9 rr for 1.6rr fast enough. So I used my stockers
    Curious,
    Why didn't you do it / help / watch?
  4. #24 Re: Should my valvetrain be ok for an S1X cam?
    Feb 2009
    flintnasty MI
    1.6 roller tip rockers will make about 25-30whp less than stock rockers, as well as float your valves much sooner.
  5. #25 Re: Should my valvetrain be ok for an S1X cam?
    Feb 2009
    flintnasty MI
    130's are not needed.
    105's are plenty...also, running a stock chain/dampner is fine as well on 105's or 90's.
    105s float on s1x and XP cam cars passed 5800rpms or so.. its not the end of the world but you lose quite a bit of power.
    I wouldnt trust an LS6 spring lift wise on a xp/s1x. Good chance you will be running into coil bind.
  6. #26 Re: Should my valvetrain be ok for an S1X cam?
    Kinda funny that consistency ruins performance in this specific application.
  7. #27 Re: Should my valvetrain be ok for an S1X cam?
    Buffalo
    why would u shift that cam higher than say, 5900rpm? sounds like more trans abuse than gains from the dyno charts anyways
  8. #28 Re: Should my valvetrain be ok for an S1X cam?
    Portland Oregon
    It is hit and miss with both...which is why I trust neither.
    In the end...your wallet...so, your call.
    Just giving you my side of things...that's all man.
    If you get your hands on a quality set of gears there's a Cloyes replacement chain that you can get for them that is pretty robust. I know a local guy running it in his turbo 3800 camaro. Don't quote me but I think it's the same chain you'd order for a Grand National. If anyone's interested PM me and I'll get the info on the chain from him.
  9. #29 Re: Should my valvetrain be ok for an S1X cam?
    GTX Level Member crbquist's Avatar
    Massachusetts
    I can't see how that's possible. Rollers are easier on the valves then stock rockers. The motor should rev easier with the rollers.
    01 Silvermist GTP - E85 - Cam - Heads - Phenolic IC - Polished Gen V - Stock trans...
  10. #30 Re: Should my valvetrain be ok for an S1X cam?
    Buffalo
    thyat was the first thing I noticed with rr My engine loved to rev and was very smooth
  11. #31 Re: Should my valvetrain be ok for an S1X cam?
    Massachusetts
    Where are you getting this info from? I've been told by many people that 105s are just fine. I was taken for a ride just the other day in a buddy's gtp that has an xp and 105s and it would not stop making power even at nearly 6500rpms
  12. #32 Re: Should my valvetrain be ok for an S1X cam?
    Quote Originally Posted by crbquist View Post
    Stock rocker ratio changes at high lift.
    motor's he's measured IIRC.
  13. #33 Re: Should my valvetrain be ok for an S1X cam?
    With no proof other than heresay.
    Plenty of people have ran 105's/LS6's without issues for years.
  14. #34 Re: Should my valvetrain be ok for an S1X cam?
    Massachusetts
    So would it be better to run stock rockers rather than rollers?
  15. #35 Re: Should my valvetrain be ok for an S1X cam?
    yes.
    costs less too.
  16. #36 Re: Should my valvetrain be ok for an S1X cam?
    Massachusetts
    yes.
    costs less too.
    Good thing I still have them
  17. #37 Re: Should my valvetrain be ok for an S1X cam?
    Feb 2009
    flintnasty MI
    I dont know a single person that has never had issues related to too much lift and not enough clearance using these parts... Remember everyone breaking valvesprings not to long ago?
    There is a thread on CGP right now where zoom and I put all the specifics out there. Its quite obvious stuff and it has not been a secret. Just because people like to do things wrong does not mean that I am automatically retarded for bring this up.
    I do typically seem retarded trying to back the things I say up with factual measurements, real world experience, and common sense.
    Floating valves on a M90 is not nearly as voilent as it is on a turbo setup, but it is happening.... As I said its a small issue and your average ricer is not going to notice 10-20whp missing.. Most everyone with this "setup" can prove valvefloat when their boost starts to spike up right around 5800 rpms. People without valve floating issues do not have that boost rise.
    In a turbo car valve float does not raise boost, but it does decrease turbo speed and airflow (as the turbo is regulated by the pressure ratio of the motor).
  18. #38 Re: Should my valvetrain be ok for an S1X cam?
    Lawrence MA
    iv'e done it once, the install with me and my brother, however it spun a main bearing 50 miles after the build. I just don't have the time or space to do it over again. and besides, Bill is a Professional
    Here is the pic of the rockers i have. i believe they are the 3rd gen rockers to be exact. at stock ratio.
    those are whats in my valvetrain as far as running the S1X on stock heads.
  19. #39 Re: Should my valvetrain be ok for an S1X cam?
    Buffalo
    ^^ those look a lot like my 1.9rr Where did you find those in stock 1.6 ratio? I been looking everywhere for those
  20. #40 Re: Should my valvetrain be ok for an S1X cam?
    Yeah, I do.
    If you remember right as well those were COMP CAMS #105's...also it wasn't just the 3800 community...tons of others that used THAT specific batch were snapping springs. They were a bad batch from Mexico. I'm talking Crow 105's, which have had a awesome track record.
  1. Valvetrain noise?
    By shawn3091 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-30-2011, 01:54 PM
  2. HELP PLEASE valvetrain bolts
    By KwazrollinZ28GTP in forum Off Topic Discussion
    Last Post: 01-14-2011, 05:42 PM
  3. Valvetrain Questions
    By Bedwards in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-16-2010, 07:55 AM
  4. Can valvetrain noise cause KR?
    By Infinity9999 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-19-2009, 09:02 PM
  5. Springless Valvetrain
    By SyntheticShield in forum General Tech Discussion
    Last Post: 12-21-2008, 01:10 PM
