Thread: L67 Lumina 3" exhaust?
Results 1 to 20 of 26
  1. #1 L67 Lumina 3" exhaust?
    Nov 2011
    Bayamon, Puerto Rico, Puerto Rico
    should i do a 3" exhaust???
    boost is at 6PSI at WOT
    has 260hp/255tq
    stage 1 intense blower cam
    headers
    FWI
    lites 104s
    180 Tstat
    3.4 pulley
    2 1/2 exhaust
    tuned for the 3.4
    i dropped to a 3.2 and got 3* KR so i took it off
    i plan on doing some valvetrain work and need exhaust work since with headers everything is hitting everywhere...
    would i get any benefits from a 3" exhaust????
  2. #2 Re: L67 Lumina 3" exhaust?
    Jun 2011
    Detroit, MI
    I think it might lower KR but also lower torque.
    iLoveSpade
  3. #3 Re: L67 Lumina 3" exhaust?
    Nov 2011
    Should i do it?
  4. #4 Re: L67 Lumina 3" exhaust?
    Jun 2011
    Detroit, MI
    Probably won't do much, what headers you got? If you don't need a cat, then remove it, or get a hi-flow one. 6 PSI seems low though, isn't stock pulley at WOT like 7?
    iLoveSpade
  5. #5 Re: L67 Lumina 3" exhaust?
    Jun 2011
    Detroit, MI
    I just noticed this is a Lumina, is the exhaust the same dual and everything as the GP? If not, then I would go 3".
    iLoveSpade
  6. #6 Re: L67 Lumina 3" exhaust?
    nah your stock catback flows fine till 350 hp
    To me it sounds more a tune problem than anything. You need a good custom tune to gain everything out of the cam you have.
  7. #7 Re: L67 Lumina 3" exhaust?
    Nov 2011
    The lumina exhaust has like 5 90 degree tubing its never comparable with the gtp exhausy! i know tune is so so but i still need to.make a new exhaust. This is why im asking if it helps to have 3" exhaust
  8. #8 Re: L67 Lumina 3" exhaust?
    Stock size is 2.5 give or take and at the bends around 2, and with how much power you are putting down its not an issue at this point.
    you''d just be spending on something you dont need to have.
  9. #9 Re: L67 Lumina 3" exhaust?
    Quote Originally Posted by Hippo Machine View Post
    *sigh*
    Hippo, stick to leaves.
    Quote Originally Posted by stonecold0469 View Post
    Pics would probably help of your current exhaust setup. 3" probably isn't going to do anything to really help...
    A cammed car on a wideband with headers should have no problem running lower than a 3.4"...sounds like a solid tuning issue like Cam said.
  10. #10 Re: L67 Lumina 3" exhaust?
    Nov 2011
    Five, its not the same with the gtp than with a lumina. It is very diferent but still...i have to do a new exhaust because mine's crap!
  11. #11 Re: L67 Lumina 3" exhaust?
    Nov 2011
    So ill just redo the 2 1/2 exhaust???
  12. #12 Re: L67 Lumina 3" exhaust?
    Post.
    Pictures.
    Of it.
    Also.
    No, get a re-tune guy...
  13. #13 Re: L67 Lumina 3" exhaust?
    Florida
    Lumina right? like a 95-00 body? if so its exhaust is 2 1/4 not 2.5...
  14. #14 Re: L67 Lumina 3" exhaust?
    Nov 2011
    Forget about tuning it for a while, i need a new exhaust! Thats it! Mines crap! All bend up, welded everywhere and has areas where is hitting my car.
    Would i lose?
    Would i gain?
    Or i should just redo the 2 1/2?
    Im not trying to get rid of kr by doing the exhaust
    I just need a new exhaust and since its the same price thats why i ask!
  15. #15 Re: L67 Lumina 3" exhaust?
    Nov 2011
    Phoenix thats correct!
  16. #16 Re: L67 Lumina 3" exhaust?
    Nov 2011
    Someone???
  17. #17 Re: L67 Lumina 3" exhaust?
    Jun 2011
    Detroit, MI
    You will not lose anything since you have to replace it anyways. Probably gain some. Yay!
    iLoveSpade
  18. #18 Re: L67 Lumina 3" exhaust?
    Bunnell, FL
    pride for hippo can either be won or lost on this playing field
    anyways pics of the exhaust?
    I'm a Sex Offender
  19. #19 Re: L67 Lumina 3" exhaust?
    That doesn't look bad at all.
    Thats a little worse, but granted you go mandrel its probably more than adequate.
  20. #20 Re: L67 Lumina 3" exhaust?
    Nov 2011
    Im gonna do it mandrel then! where can i find some mandrel??? Ill probably move the muffler to the drivers side! To see if I can eliminate the last corner
  1. Any 2.25" in by 3" out by 5" long exhaust tips out there?
    By Xanthous in forum Visual/Body Modifications
    Last Post: 06-05-2011, 09:09 PM
