Thread: Smog pump failing
Results 1 to 8 of 8
  1. #1 Smog pump failing
    kansas
    So I have an 08' GP with an air pump and it has gone bad n throwing a code. Can I just unplug it and reset the light n b ok or is there some kind of 02 simulator like delete availible???? I'd replace the pump but its pretty expensive and I need to sell car to get an suv for that I have a new member to the family on the way!
  2. #2 Re: Smog pump delete?
    Bunnell, FL
    when did they start doing this?
    mine is a 97 cali emissions car
    I'm a Sex Offender
  3. #3 Re: Smog pump delete?
    Out West
    Gee, more of this hippie crap?
  4. #4 Re: Smog pump delete?
    kansas
    great another smartass punk posting
  5. #5 Re: Smog pump delete?
    You've made a mistake by not creating a new thread and posting in one from 2009.
    Its okay to reference old threads in your new one, but bringing it back from the dead is something we frown upon.
    Moved your thread.
    Despite you not appreciating Nixon's comment, insulting him isn't a great path to go down.
    You're no longer in the right, but right there with Nixon.
    As for your issues: Why would you sell a car in this manor? Thats pretty backwards.
    You can't tune the code out because you can't touch your PCM.
    You can get one from Will for a large cost, may or may not work. Depends on the make of the PCM.
    Or get an 05 PCM, then your fuel gauge will read backwards.
  6. #6 Re: Smog pump failing
    Bunnell, FL
    wow nixon was def referring to the emissions garbage. esp cali emissions
    I'm a Sex Offender
  7. #7 Re: Smog pump failing
    kansas
    Sorry if I was in the wrong!!!
    Not selling car like that, I'm actually getting it fixed under warranty!
  8. #8 Re: Smog pump failing
    Out West
    Quote Originally Posted by z3r0 View Post
    Yep.
  1. smog emisions pump help
    By grandprixxx94 in forum General Tech Discussion
    Last Post: 09-07-2011, 06:52 PM
  2. A.i.r./smog pump location
    By roderick in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-18-2011, 09:05 PM
  3. Smog pump delete?
    By 2001GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2009, 06:53 PM
  4. Smog pump question.. please help.. I'm having so much trouble with this thing.
    By NaturallySmashed in forum General Tech Discussion
    Last Post: 04-01-2009, 11:32 PM
