Thread: P0171 set on decel//update has another code
Results 1 to 7 of 7
Threaded View
  1. #1 P0171 set on decel//update has another code
    GT Level Member PWNED's Avatar
    Jul 2008
    Hooksett,NH
    So i installed my Dynotech Transmission today.I had zzp program my pcm for the 3.29's,42.5's and the other basics that come with their pcm.I am setting a lean code on decel.Any way to fix that?More of tuning issue?My car has never set that code before untill i installed this pcm.I also checked all the vac lines.I am running good on wot.But once off it goes lean.The code was set at 1000rpm with 1% Throttle angle.When i had my buddy watch the tech 2 he said it was going lean right after i let off the gas from a wot run.
    02 Regal GS
    ZZP Headers/ 42#/ Intake/ S4 zzp sc/ Ported Lim/ LQ4/ HPT/ 3" to SuperTurbo/ Phenolic IC with 2.8 pulley/ XP/ Ported Heads
    PB-------12.3 @ 110.......312hp/350tq
  1. How to Trace Vaccum leaks for P0171 [*]
    By Toasty in forum How To Write-Ups/Tech Tips
    Last Post: 04-18-2012, 09:52 PM
