Thread: IC question
Results 1 to 12 of 12
  1. #1 IC question
    GTP Level Member David99GTP's Avatar
    Florida
    I asked this on another thread but decided to post its own as to not hijack another thread
    I am starting the parts buying for my next wave of upgrades. All air flow this round. TB, SC, IC, Hedders/complete exhaust.
    Whats the best and biggest IC for our cars?
    1999 GTP
    2002 Chevy 2500HD lifted on 36" Swampers
    http://www.cardomain.com/ride/2619487
  2. #2 Re: IC question
    May 2008
    staten island,NY
    i think 2.5 inch is the biggest from zzp. i dunno if there is a 3 incher. i run a 1inch short stack from zzp
  3. #3 Re: IC question
    GTX Level Member kingd44's Avatar
    Feb 2008
    newyork
    u have the shinyest car ever how the hell do u make it so shiny lmao
  4. #4 Re: IC question
    Florida
    Quote Originally Posted by kingd44 View Post
    My car? I use a Rotary buffer and do the whole car every 6 months or so. Final waxing I use Meguiar's NXT tech wax and detail spray.
    1999 GTP
  5. #5 Re: IC question
    Feb 2008
    newyork
    it looks ridiculous lol.....i gotta try that
  6. #6 Re: IC question
    May 2008
    McHenry IL
    my thread?? lol =]
  7. #7 Re: IC question
    Jan 1970
    Maquoketa, Iowa
    The ZZP stg 2 intercooler is a 2.25" IC. W-body store did have 3" IC but do not sell them anymore. There might be others but they either don't sell them anymore or hard to find. I think the stg 2 is the best plate around now. ZZP is working on a new IC design also.
    With that being said, you can find a stg 2 plate for around $400. If you want to get the most benefits out of it, there are new FMIC to take a look at. The two that I really like that provide a lot more cooling capacity over zzp's stg 4 radiater would be something like this below. Probably one of the most overlooked features is the water temp. sender bung it has installed: Air to Water Heat Exchanger
    ZZP also made a heat exchanger like this but I can't find it on their site anymore...
  8. #8 Re: IC question
    Florida
    Quote Originally Posted by GTPJOE90 View Post
    my thread?? lol =]
    Yeah LOL, but your thread answered a few questions I was wondering myself. I have been thinking of IC the car for a while now but wasnt sure the best route. Some $$ to make a wrong decision. From what I am hearing its a waste of $ to buy the kit from ZZP and I'm better off piecing it out.
    This forum is the best for good info.
    1999 GTP
  9. #9 Re: IC question
    Moore, Oklahoma
    My best advice for you, is stay away from a ZZP Stage 3 IC, there discontinued for a reason ya know. The plastic insert always cracks and causes vacuum leaks. When it cracks, good ol' Zooomer won't replace it, he'll tell you that you misinstalled it and its not covered. What he won't tell you is the plastic and aluminum and different termo expansion rates which causing the issue. Moral of the story, DON'T BUY A STAGE 3.
    And, i'd agree its best to piece together your own IC kit. The VW radiator are cheesey IMO, on a nice show car like yours, get the froozeboost unit hand down. The VW radiators are weak and they will look like **** after driving it around a little bit. Not worth it, I donno why people even bother buying VW radiators nowadays when there are WAY better options out there now.
    As for a fill point, don't use a cheesy fill T ZZP sells, either use a nice looking Fill T from a Cobalt SS or CSR on one of the lines, or custom make a reservior which is easier said than done. I'm trying to set myself up with a reservior at this point, hope to have something clean figured out soon. If your interested in using a nice looking filler T, I have a CSR Filler T (polished alumiunm) w/ a Chrome 7psi Walker Cap, and Earls 3/4" AN barb fittings here that will be for sale soon if interested.
    Next, hands down run a GM Pump. The Flojets are noisier than hell and tend to be unrealible. The GM is more expensive, but realible. I shoot for realiblity so GM is for me.
    For your IC bolts, use all stainless steel hardware and for hoses use 3/4" throughout the system for max performance.
    Also, use OEM or Felpro S/C gaskets, don't get the garlocks... unless you want to pull it back apart a few months later and replace leaky ass gaskets.
    Theres my advice for ya. I've built 3 IC systems so far, so take my advice for what you think its worth.
    Oh yeah, and I said in another thread the biggest and best IC system ever made for the L67 is the Thrasher Intercooler. It is the most expensive too.
    Good Luck...
    Shawn W. Larsen
  10. #10 Re: IC question
    SE Level Member BlackGS's Avatar
    Central Jersey
    I have the ZZP stage 2. Nice unit, but it does heat soak bad. I have been planning on getting a 1/4" or 3/8" sheet of garolite G11 and cut a spacer between the core and LIM.
    I have the frozen boost FMHE. Nice unit, and keeps the temps right at outside air temp.
    For easiest filling, have two open points in the lines. I put a 1" T-fill up front, and the Cobalt reservoir on the return. I also just bought this coolant tank at Wal-Mart for $7, and fitted it with 3/4" barbs to use as an inline icebox.
    2000 Regal GS | Stattama Twin-Charge with Comp Turbo 6765 | 12.55 @ 110 15psi | Now running 20psi on E85!! |
  11. #11 Re: IC question
    Aug 2008
    connellsville, pennsylvania
    i got a guy in newyork thats making intercooler cores you can check out his work at IRC Fabrication his cores use a bar n plate design not a heter core tube n fin they are more efficiant i will post picts later. his name is marty he is willing to do a group buy to cut the cost down. i had a intense core that broke and he replaced the heat exchanger with his design and it worked better. iam getting a genv put on my car now i will let all know how this works he dwsigned the core and heat exchanger.
  12. #12 Re: IC question
    Florida
    Cool, keep us posted!!
    1999 GTP
  1. Another Question...
    By JoeMama in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-29-2008, 01:33 AM
  2. I got a question
    Last Post: 06-11-2008, 05:04 PM
  3. Question
    By Tyler_06 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-23-2008, 10:20 PM
  4. cai question
    By kingd44 in forum Off Topic Discussion
    Last Post: 02-19-2008, 07:27 PM
  5. question
    Last Post: 02-09-2008, 10:43 PM
