Thread: Stage 6
Results 1 to 12 of 12
  1. #1 Stage 6
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    what do you guys think about the Stage 6 from 3800performance.com? I want to skip all BS and go big with this one. it says only 04 GTP but my 06GT has same engine and i'm guessing it will still work...
    Would I need any mods to support this stage 6? I'd prefer to purchase this stage since it has everthing I already want and is only about 2,500 bucks
    heres the link:
    3800SC Stage 6 Performance Package: 3800 Performance
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  2. #2 Re: Stage 6
    Banned
    Wichita Falls, Texas
    Honestly there are much better ways to go about spending $2,500 if you have it rather than buying this kit for no more performance gains that it promises.
    First off, what are you looking to do with this car? Just wanting some extra 'pep' for your daily driver or are you going to want and try and put some serious power down?
  3. #3 Re: Stage 6
    Aug 2008
    Fayetteville, NC
    rite now it is my daily driver til i get my truck back up but I'd like to put some serious power down. I'm talking when at the strip, one punch and my leather is already soaked with rubber smell...my sonoma only needs a clutch FTW
  4. #4 Re: Stage 6
    I live here. UR LOSN's Avatar
    Rockford, IL
    I'd get the truck running before I would dump any money into that car. make sure the other one is reliable....so when you do upgrades, you are not stranded without a vehicle.
    jmo..... finish one project at a time.....
  5. #5 Re: Stage 6
    Banned
    Quote Originally Posted by UR LOSN View Post
    Without a doubt, make sure you have something else to drive if you want to make any kind of power with your GP. You will break something at some point in time, not maybe, or possibly. Without a doubt your GP is going to break down on you once your modded.
  6. #6 Re: Stage 6
    Donating Users blowfishRus6's Avatar
    g.a.
    you might need a built tranny with that power too. and i agree there is much better ways to go about it. cam and valve train componets from zzperformance are about 700$ and that is the xp cam that makes the most hp on stock heads. headers 350-600. you already have an intake. pulley 60-80 bucks i think. some colder plugs 40$. tune. 200 bucks depending on where you get it. i would get it dyno tuned or from overkill. he works with zzperformance and could tune it pretty good for the cam. i dont really trust the off the shelf tunes they give you.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  7. #7 Re: Stage 6
    g.a.
    you might need some injectors to depending on how low of a pulley you go with. most likely you will. the best tune would be to get an hpt and do the tunning you self. if your going to invest that much money into it mine as well take the time to learn how to tune your car so everything runs as good as it can. you also might need to upgrade your MAF.
    its slow.
  8. #8 Re: Stage 6
    Apr 2008
    Chillin at the Beach , VA
    I talked to a couple people on here about that stage 6 kit. I was thinking about getting it and was told it wasn't worth it. Some parts in it aren't really good and some you won't need.
  9. #9 Re: Stage 6
    g.a.
    agree
    its slow.
  10. #10 Re: Stage 6
    GT Level Member Meemperor's Avatar
    Toronto, ON, Canada
    Just got Turbo.
    Cartuning Performance
    Lumpy Gen 3
  11. #11 Re: Stage 6
    SE Level Member BlackGS's Avatar
    Central Jersey
    In the stage 5 package they are giving you 1.8 rockers, and the stage 6 says it includes the stage 5, but now has a cam? Seems like a lot of money for a setup with no injectors or intercooler. I highly doubt you would run as fast as they are saying. Look at some times and mods on the forum.
    For the same money, you could go with intercooler, 2.8-3.0 pulley, injectors, headers, and tune. That would put you in the low 13's for sure on the street. A mild turbo setup could also be purchased for that amount.
    2000 Regal GS | Stattama Twin-Charge with Comp Turbo 6765 | 12.55 @ 110 15psi | Now running 20psi on E85!! |
  12. #12 Re: Stage 6
    Aug 2008
    Fayetteville, NC
    ok good suggestion blackgs
  1. intense stage 3 cam
    By whitcomb in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-16-2008, 01:23 AM
