Previously asked a question about what could cause fuel tank to collapse, and if faulty evap system could collapse the tank.
Finally got access to scanner and was able to read 2 codes:
P0440 and P0452, both related to the evap system.
P0440 seems to be a generic evap system code, while P0452 references
low pressure sensor input.
What I know: Fuel tank is collapsed, without any indication it has been physically hit or dinged from below. Fuel level sending unit is stuck at 1/4 tank. It is passing a solid believable reading to the PCM (not open or floating around), and I suspect it has somehow wedged against something on the collapsed tank and stuck. It did read correctly after install, until tank got low for the 1st time.
Here's my thinking, please provide any insights or information that might be helpful.
Bought the car approximately 6 months ago, and fuel level sender did not
work from time of purchase. Only code at time of purchase was 1 that indicated "leak or missing gas cap" (don't remember the #. I suspect the person I purchased from knew he had an evap problem, erased the codes, and avoided completely tightening the gas cap to prevent tank collapse. Soon after buying car, my son reported hearing noise from the rear of the car, which in hindsight was likely the metal tank "oil canning" as it collapsed. Cannot be sure when the codes were set, since "check engine" light is either burnt out or disconnected.
I suspect fuel tank was collapsed when I first replaced fuel pump/sender unit, but not absolutely sure, due to unit trying to "kick" to 1 side during install makes me think the tank was collapsed and slanted.
Do I need to erase the codes, or will they update and go away if the old sending unit pressure sensor was bad and I now have new (presumably good) sensor that came with new pump unit? I'm wondering if a plugged purge solenoid caused vacuum to be pulled, and also the "low pressure sensor input". Or is it more likely that a bad pressure sensor (or wiring) caused a too hard a vacuum to be pulled on the tank?
Either way, don't mind replacing the tank, but want to make sure to determine root cause so I don't just collapse a 2nd tank.
Any insight appreciated!!
