Thread: high revs as i start car
Results 1 to 20 of 24
  1. #1 high revs as i start car
    Warren, MI
    this cant be right. i try to start the car and is hesitates but when it turns over, it idle's at about 3000rpm and slowly climbs to 4000rpom.
    HELP!!!!!
  2. #2 Re: high revs as i start car
    SE Level Member silvercharged03's Avatar
    Sep 2011
    Holly, MI
    It sounds like it could be your tps (throttle position sensor)
    open cone ftw
  3. #3 Re: high revs as i start car
    TPS or a monster vacuum leak...either way.
  4. #4 Re: high revs as i start car
    Warren, MI
    ok... just got dont doing a lot of work and i already suspected a vac leak at the lim. maybe ill just replace both those... lol
  5. #5 Re: high revs as i start car
    What work was done...
    And check engine lights?
    Did you do the work yourself?
    We need details, boss.
  6. #6 Re: high revs as i start car
    Warren, MI
    changed every gasket from the head gaskets up, new MAF, new wires & plugs, new front O2 sensor, new ECT sensor.
    did the work myself.
    no DTC's yet, i dont want to run it long enough for the PCM to throw any at that high of rpm's
  7. #7 Re: high revs as i start car
    Sep 2011
    Holly, MI
    Very possible it is a vacuum leak then...checked all your vac lines and make sure they are all hooked up from previous work done
    open cone ftw
  8. #8 Re: high revs as i start car
    Quote Originally Posted by Jrs1987 View Post
    High RPM's won't effect how or when it'll throw a code...if somethings wrong, all it needs is a few seconds to do so...unplug the MAF sensor, start it again...see if that changes anything.
  9. #9 Re: high revs as i start car
    GT Level Member shart's Avatar
    Oct 2011
    Reading PA
    Hmmm.... Sounds a little familar... on top of checking everything that has been suggested, have you by any chance removed the throttle screen for the MAF in the throttle body? That screwed with my rpms at idle something fierce until i put it back in.
  10. #10 Re: high revs as i start car
    Quote Originally Posted by shart View Post
    It would...but not anything over 1000-1500 rpm's...this is another issue.
    Although if the screen is out...put it back in.
  11. #11 Re: high revs as i start car
    Oct 2011
    Reading PA
    Im going to have to disagree... when mine was out my RPMS were between 2 - 3k at idle... put it back in and it was fine... It was strictly because of that screen being out... no other issue.
  12. #12 Re: high revs as i start car
    Warren, MI
    Ya I tried unplugging maf, iac, tps, egr, all that only 1 at a time tho. No I didnt remove the tb screen. Still stock intake. Also, headers got installed. Idk how I forgot to list that. Lol fixed a couple vacuum t connectors. Also discovered that even though it idles at about 4000rpm, the throttle butterfly is still closed. Its not stick cause I can open it both with the gas pedal and with my hand on the tb.
  13. #13 Re: high revs as i start car
    Oct 2011
    Reading PA
    Only thing i could suggest... is double check the vacuums and buy an IAC and TPS and replace one at a time... if its the same, quick take it out and try the other one... If neither of them do anything, take them back! Have to eliminate them as the issue before you really start looking deep and putting down alot of cash
    FYI... make sure you find the right sized tools to do the trick... the bottom security bolt on the TPS can be a ***** to get at straight on.... when i finally got it out i replaced it with a regular 10 mm bolt so i can easily use a wrench to get at it.
  14. #14 Re: high revs as i start car
    GT Level Member 99GTRED's Avatar
    Oct 2011
    Grand Rapids, Michigan
    my car did this too. i had to replace the MAF and the TPS
  15. #15 Re: high revs as i start car
    Oct 2011
    Reading PA
    That would be the next step id take if those two dont do it... disconnect MAF sensor and take it out and clean it real good with MAF sensor cleanor. Unless its completely F'ed you should be able to get away with a good cleaning.
  16. #16 Re: high revs as i start car
    Oct 2011
    Reading PA
    You can help narrow the issue... when its idling like that... if you very very gently and very quickly hit the accelerator what happens? Does the idle stick a couple hundred RPMs higher or does it come right back down to where it was?
  17. #17 Re: high revs as i start car
    Warren, MI
    Ive already replaced the maf, though it was a cheap Ebay maf so it could still be bad. And it jumps and status 500 to 1000rpm higher when I tap the gas pedal.
  18. #18 Re: high revs as i start car
    Oct 2011
    Reading PA
    So it sticks? I'm def leaning towards tps or IAC or the maf is reading incorrectly... also if you still have original maf I'd spray it out good... never know what your getting with no name eBay parts.
  19. #19 Re: high revs as i start car
    Oct 2011
    Reading PA
    Also, I'd pull the throttle body off, clean it real good and remove all remnants of old gasket and get a new one on there so you can eliminate leaking gasket. Doubt that's the issue but its another thing to consider.
  20. #20 Re: high revs as i start car
    Oct 2011
    Reading PA
    FYI I got a spare tps and IAC in working condition laying around if u want them ill give them to you cheap. They are the stock ones... let me know and when u find the issue please post it.
  1. Revs go up/not changing gears?
    By SUGAR in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-18-2011, 11:07 PM
  2. car revs like crazy after I removed throttle body
    By splatter in forum General Tech Discussion
    Last Post: 02-28-2011, 01:17 AM
  3. trans revs out
    By kbmukdk2316 in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 11-01-2010, 02:50 PM
  4. High Revs, Late Shifting, and low HP
    By Wigsos in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-30-2010, 09:24 AM
  5. engine revs when putting into gear
    By breeze12 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-07-2009, 09:28 AM
