Thread: Building a motor for my 2000 GTP
Results 1 to 7 of 7
  1. #1 Building a motor for my 2000 GTP
    GT Level Member ls1camino's Avatar
    Laurel, MD
    This coming spring, I was planning on installing a Gen V, Intercooler, VS Cam, and a built transmission. Well, with 117k miles (probably close to 125k by Spring), I added head gaskets to the list of replacement parts.
    Then I got to thinking, why break my back removing and installing heads and cleaning up the block, when it would be 100 times easier to just pull the motor/trans as one, and replace them that way. I'm tossing around the idea of building a "fresh" motor. It will give me a nice Winter Project I can occupy myself with while waiting for warmer weather.
    I'm thinking of starting with a L26 short block (junkyard pull), pulling it all apart, replacing the bearings and rings and putting it back together with ARP hardware. I'm going to just throw some home-ported L32 heads (bigger valves, right?) on her with the the LS6 Springs and call it a day.
    I'm concerned that with the L26 Block, I'll run into PTV clearance issues with the VS Cam. Am I worrying about nothing? Also, is there any difference between the blocks and heads externally? I don't want to run into any last minute fabrications I need to do. I just want to swap over my stock sensors, covers, and accessories then fire her up to go get dyno-tuned.
    2000 Pontiac Trans Am WS6 M6: 427ci LS3, Built T56, Moser 9" w/ 4.11 Gearing, Full Suspension, and 6-point Cage.
    2000 Pontiac Grand Prix GTP: Twincharged (T67 Turbocharger).
    2007 Chevrolet Silverado 3500 Dually: Intake, Exhaust, and Tune.
  2. #2 Re: Building a motor for my 2000 GTP
    just buy a L67 block, cheaper.
  3. #3 Re: Building a motor for my 2000 GTP
    swift current,sask.
    go with an xp and do it right, you wont be sorry trust me.
  4. #4 Re: Building a motor for my 2000 GTP
    Willoughby, Ohio
    i say do it. new 9.4 compression l26 block with the stronger rods and a cammed genV setup, it could even be a mild cam and id bet you would still be happy
  5. #5 Re: Building a motor for my 2000 GTP
    Laurel, MD
    Not worth the bump in compression?
    I can find an N/A GP around here a lot easier than a GTP. I just said L26, instead of L36 cause of the powdered rods. I'm sure a L36 will survive the mild build I am planning.
    My questions are still valid.
    Quote Originally Posted by whiney View Post
    I don't want to lose the reliability of the timing chain in my daily driver by upping the springs to 105# to properly rev out the the XP. I'm giving up a little power for reliability. The 75-shot of nitrous that I already have on the car will more than supplement the slight difference between the two cams.
  6. #6 Re: Building a motor for my 2000 GTP
    lower compression is just easier if you ask me, less chance at popping a piston because you can run alot more boost on lower compression than high compression.
  7. #7 Re: Building a motor for my 2000 GTP
    the VS does just as well as the XP power wise. it's been proven a number of times.
  1. How-To: Replace the Blower Motor on a 2000 Grand Prix
    By WalterWhite in forum How To Write-Ups/Tech Tips
    Last Post: 09-04-2015, 12:00 AM
  2. putting new motor in 2000 monte ss from...
    By 0LmtdGP3800 in forum Chevrolet Monte Carlo
    Last Post: 11-29-2010, 01:07 AM
  3. 2000 grand prix gtp motor
    By bigdaddy77 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-14-2009, 01:09 PM
  4. please help me! building motor
    By notagtp01 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-27-2008, 08:00 AM
