Thread: car wont start need help
Results 1 to 14 of 14
  1. #1 car wont start need help
    GTP Level Member 2001goldGTP's Avatar
    california
    i changed my spark plugs, thats it, now the car wont start.I have changed the Crank position sensor, the ICM and the PCM.
    So wtf is going on with this thing?
    It cranks with no issue, it just has no spark.
    Also does anyone have a wiring diagram for the motor?
    xp'd
  2. #2 Re: car wont start need help
    KSteelwheelzJ klj5022's Avatar
    New Carrollton,MD
    1,2,5 Front of engine
    2,4,6 Rear of engine
    Numbers from passenger side to driver side
    I just wish the police loved my car as much as i do 3.5,160 Stat,HAI,ZZP F/R STB, SSAC Headers, Reptile PCM
  3. #3 Re: car wont start need help
    california
    thanks man, but i meant the wiring diagram for the wires in the wiring harness that lead from the ICM out
    xp'd
  4. #4 Re: car wont start need help
    Charles City, IA
    ok so you changed plugs and then the car wouldn't start?
    SMGPFC Two Nipple General
  5. #5 Re: car wont start need help
    california
    yup, when we changed the cam the car wouldnt start for two days then it came to life, and this time its not going to start, same problem no spark, i checked all the fuses too
    xp'd
  6. #6 Re: car wont start need help
    Sep 2011
    MI
    Did you disconnect the battery? If you did it could be in security mode. If you did't maybe you should... reset the cpus.
  7. #7 Re: car wont start need help
    california
    battery has been off and one for a long time
    xp'd
  8. #8 Re: car wont start need help
    Sep 2011
    Canada
    How about a bad coil pack? Sometimes you can also forget to connect back the plug going to the coil pack if you needed to make room for yourself to work. I know I had to unplug it for more room. It's in the front on top of the valve cover.
  9. #9 Re: car wont start need help
    One bad coil pack will still let the engine start.
    Does it crank?
    Does it sputter?
    Did you disconnect anything electrical besides plugs and the battery?
    Check your connection at the pcm to ensure it's snug
    Check your connection at the icm to ensure it's snug.
  10. #10 Re: car wont start need help
    SE Level Member 94grandprixNOwhipple's Avatar
    Oct 2011
    Indiana
    My brother had a similar problem like this in his grand am. He would do something minor to it, and the car wouldn't start for a while, than it would magically run fine. Ended up being the cluster in the dash shorting out, and throwing codes everywhere.. Double check your wiring to your plugs, check everything electrical near the area you worked on your car. I'm in a computer class, and my teacher always say's double check everything before you turn it on.
  11. #11 Re: car wont start need help
    Quote Originally Posted by 94grandprixwhipple View Post
    Probably also tells you it worked fine until you let the smoke out.
  12. #12 Re: car wont start need help
    Oct 2011
    Indiana
    nope. Never happened to me. I never mess up. I'm a Boss.
  13. #13 Re: car wont start need help
    california
    I found a regal in the junk yard, I took the icm, coils, wiring harness, I had already replaced my cps. With all regal parts it runs, if I use any of my stock parts it wont. More importantly it runs thanks for the help
    xp'd
  14. #14 Re: car wont start need help
    Look at the hold harness. Might have rubbed and caused an issue and popped the ICM's mind.
  1. 1998 grand prix gt wont randomly wont start!!
    By franklin829 in forum General Tech Discussion
    Last Post: 01-18-2011, 01:26 PM
  2. Car wont start
    By jluca in forum General Tech Discussion
    Last Post: 12-01-2010, 08:37 PM
  3. my car wont start
    By whereswaldo01 in forum General Tech Discussion
    Last Post: 11-18-2010, 05:48 PM
  4. ran out of gas , now it wont start
    By jbon64 in forum General Tech Discussion
    Last Post: 12-25-2008, 02:27 PM
  5. Car wont start
    By 94GTRoyalty in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-13-2008, 01:57 PM
