Thread: Reusing valve cover gaskets
Results 1 to 8 of 8
  1. #1 Reusing valve cover gaskets
    I searched and didn't come up with anything but i was wondering if i would be able to reuse the valve cover gaskets when i put my 1.9's in. If i can save $50 that would be awesome. Thanks.
  2. #2 Re: Reusing valve cover gaskets
    Kansas
    Nope. VC gaskets have known problems to leak... so why not replace them now so you won't have to later?
  3. #3 Re: Reusing valve cover gaskets
    they aren't leaking right now so i thought that maybe i could save the $50 and reuse them.
  4. #4 Re: Reusing valve cover gaskets
    Ocala, FL
    I hope your time to replace them later is worth more than $50.
  5. #5 Re: Reusing valve cover gaskets
    Buy them online from Advance, as pick up in local store and use a discount code to get them cheaper.
    Not changing VC gaskets and grommets is a mistake, unless you've changed them in the last 6months
  6. #6 Re: Reusing valve cover gaskets
    Just change them. You'll be glad you did. Get the blue rubber ones too and replace the grommets
    Snorlax strikes again.
  7. #7 Re: Reusing valve cover gaskets
    PA
    I reused VC gaskets once. I had only driven a few miles and needed to remove the VC to check the rockers. Other than that, replace them. Even if they only have a few weeks of driving, the gasket will be deformed and will not seal right. Replace them.
    2001 GSE
  8. #8 Re: Reusing valve cover gaskets
    GTP Level Member buck531's Avatar
    Aug 2011
    Gahanna, Ohio
    When you pull the covers and run your finger across the entire gasket (generally the bottom) and if it's flat with the cover, replace them. If they have a decent sized "bump" in them they should be ok.
    If you've never replaced them. Replace them.
    03 GS - SSAC, AEM wb, PT,SR rockers, Gen 3, 3.4, dynotech trans w/ 3.29's.
    87 Fiero GT. L67 Swap. XP, ported heads/sc. N* TB, FSIC, 2.8, 12.018 @ 113 1.71 60'.
  1. valve cover gaskets
    By busagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2010, 12:54 PM
  2. Doing LIM and Valve Cover Gaskets
    By djimmy31 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-16-2009, 07:08 PM
  3. Valve cover gaskets...
    By TorqueAutoMotiv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-27-2009, 06:14 PM
  4. Valve Cover Gaskets
    By fragrep in forum General Tech Discussion
    Last Post: 03-11-2009, 07:46 PM
  5. Valve cover gaskets
    By spenc938 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-05-2008, 07:34 PM
