Thread: PCM from ZZP?
Results 1 to 10 of 10
  1. #1 PCM from ZZP?
    Lifer h0wl0ngcanitbe's Avatar
    Marysville WA
    So I browse CL like I breath, and I found this and I just so happen to have a 97. My question is how hard would it be to install this and is their a way it could be a faulty unit? I see other parts on CL from a 97 GP so im thinkin he wreaked and is parting out any heads up before I make the purchase would be great!
    Grand prix performance PCM
    2001 4dr Black GTP Stock and staying that was... maybe
    1997 2dr Black GTP Open Cone, GXP Rims, Black Headlights, ZZP Headers, ZZP Cat Back, Bunch of suspension parts from ZZP, ZZP 10.5MM plug wires, Autolite 605s, Overkill Tune
  2. #2 Re: PCM from ZZP?
    Marysville WA
    Annnnnnd I just discovered ZZPerformance.com Im pretty sure I got Christmas for myself covered for the next few years!
  3. #3 Re: PCM from ZZP?
    zzp is not the best pcm out there.
    Id run a dhp pcm befor I ever touched a zzp one.
    and zzzp has really high prices on stuff too and alot of there mod info is outdated.
    Alot of stuff you can find on here for alot cheaper.
  4. #4 Re: PCM from ZZP?
    GTP Level Member Austins01GP's Avatar
    Nov 2010
    Maryville, MO
    http://www.grandprixforums.net/safel...car-17482.html
    ^ Read this if you havnt seen it yet little long way important info..
    and there are lots of vendors out there besides them
    someone on here could even tune your car if your interested
    // 1992 Nissan 300zx Twin Turbo (More RWHP than the Comp G)
    // 2005 Comp G
    CLICK ME!! for my Z Build and Comp G
  5. #5 Re: PCM from ZZP?
    zzp 1.0 pcm is probably damn near identical to the dhp 1.0 pcm so it really doesnt matter. both will end up either helping or hurting depending upon how your car takes to it.
  6. #6 Re: PCM from ZZP?
    Marysville WA
    Well this is good to know, its not like it was on my hot list to do. i just saw the ad and was interested. What are some common issues/side effects of the PCM?
  7. #7 Re: PCM from ZZP?
    sometimes the timing tables are bumped, which will in turn introduce some KR to the system. sometimes it doesnt. sometimes the tables for the transmission arent exactly how youd want them. etc. etc. etc.
    it really is different for each car.
  8. #8 Re: PCM from ZZP?
    GTX Level Member cliffdawg's Avatar
    Midvale, Utah, United States
    i heart my intense but in about a couple months ima get a dyno tune locally from a guy thanks to boostedcompg
    SMGPFC #77
    94 Firehawk - #108 of 500
    97 GTP Coupe - Rebuilt Trans, F1 Hood, Front Air Dam, and Gen 5 Blower Swap than done with modding
  9. #9 Re: PCM from ZZP?
    Marysville WA
    So with the proper tuning one of these things could increase performance significantly? Id just love to see her run at her peak.
  10. #10 Re: PCM from ZZP?
    Florida
    custom tuning is where it is at! drop in tunes help but someone with a tuner can do much better. but if they dont know what they are doing they can do much worse too.....
pcm, zzp
