Thread: Rocker install?
Results 1 to 20 of 27
  1. #1 Rocker install?
    KSteelwheelzJ klj5022's Avatar
    New Carrollton,MD
    How hard is it to do a rocker and spring install? I installed my own headers took me about 7 hours with like 4 of them going to figurin out how to get the back one in without lowering the subframe. Any idea on rocker install is it kist taking alt bracket off and the valve covers. What's the degree of difficulty? And what tools are needed?
    I just wish the police loved my car as much as i do 3.5,160 Stat,HAI,ZZP F/R STB, SSAC Headers, Reptile PCM
  2. #2 Re: Rocker install?
    rockers are fairly straight forward. the springs are a little harder because you need a valve spring tool and an air compressor. unless youre awesome and do it with string to keep the valve from falling into the cylinder.
  3. #3 Re: Rocker install?
    Compression tester (used w/o the schrader and gauge in it to put air from compressor into cylinder)
    Valve spring compressor
    Magnet (for retrieving the valve locks)
    3/8" socket for vc's
    15mm socket for alt/bracket/coil bracket
    You should do the valve seals as long as you are there.
  4. #4 Re: Rocker install?
    Ohio
    might i recommend zzp's seals and not intenses. intenses went to **** on three cars real quick. pulled em out in pieces and torn up. zzps are exactly like stock but are viton seals
  5. #5 Re: Rocker install?
    ZZp's are Felpros Buy local..save moola
  6. #6 Re: Rocker install?
    Ohio
    really? dammm ill get em at work then
  7. #7 Re: Rocker install?
    New Carrollton,MD
    i just got them done for that engine fire recall. Damn i was going to do springs too looks like mechanic will have to do. I dont have a compressor and my sausage fingers would never be able to tie a string around it lol
  8. #8 Re: Rocker install?
    Buffalo
    It helps if u have a buddy there drop the locks while you are compressing the spring
    I used the viton rubber valve seals thru autozone
  9. #9 Re: Rocker install?
    or if you don't use the lever type compressor. Use a hand crank one and you can do it all by yourself.
  10. #10 Re: Rocker install?
    GTP Level Member buck531's Avatar
    Aug 2011
    Gahanna, Ohio
    Depends on what rockers you're installing. I've ran SR rockers (1.8/1.85 modified stockers) to 6100 rpm's without valve float so I never had to change the springs. Just because you're doing rockers doesn't automatically mean you're doing springs.
    03 GS - SSAC, AEM wb, PT,SR rockers, Gen 3, 3.4, dynotech trans w/ 3.29's.
    87 Fiero GT. L67 Swap. XP, ported heads/sc. N* TB, FSIC, 2.8, 12.018 @ 113 1.71 60'.
  11. #11 Re: Rocker install?
    New Carrollton,MD
    oh im reving higher and you thnk i could use a couple zipties to compress?
  12. #12 Re: Rocker install?
    Buffalo
    Nope
  13. #13 Re: Rocker install?
    Aug 2011
    colorado
    rockers is one of the first things i did to my car and i wasn't real experienced with the 3800 at the time. it wasn't a bad install really but i didn't do springs(doing them soon). i had a more experienced gtp'er walking me through it just telling me what to wrench on while he worked on another project. it can be time consuming (took my slow ass 8 hours-kept losing bolts and such) for a beginner but don't be intimidated by it. plan on a full day project,bring some experienced help and if you get it done quicker. . . . go test drive!!!
  14. #14 Re: Rocker install?
    GTP Level Member biggt's Avatar
    Jul 2010
    Montreal
    I know its a old thread.
    Im looking into 1.9 rockers from ZZP ; ZZPerformance - 1.9 Ratio Modified Rockers #04-01-00001
    is there any how to for the installation? Do i need to remove anything other then the valve covers? Keeping in mind im just changing the rockers and not going past 6000 rpm.
    and I would also get this; ZZPerformance - Rocker Install Kit #
    I would do that myself in my drive way.
    I dont want a cam because its to complicated for my mecanics skills...
    02 SilverMist GT L67 SWAPPED
    Quote Originally Posted by RedDawnGXP View Post
    Yeah plus he has a lot of weight reduction with the clear corner lights.
  15. #15 Re: Rocker install?
    you have to remove some parts to get to the valve covers. It's pretty easy i did mine in about 2 hours taking my time.
  16. #16 Re: Rocker install?
    Jul 2010
    Montreal
    but when removing the valve covers Its pretty straight foward? the rockers are easy to remove? straight forward to replace?
  17. #17 Re: Rocker install?
    one bolt. one rocker.
  18. #18 Re: Rocker install?
    Jul 2010
    Montreal
    sounds good! did you really see a difference after the 1.9 rockers? 1/4 mile times?
  19. #19 Re: Rocker install?
    Texas
    Quote Originally Posted by biggt View Post
    Yes:
    Modifed 1.9 rockers are installed.
    First thing was to remove the battery and coil packs. The dog bone mount attached to the engine hang over the valve cover.
    Valve cover was fairly dirty:
    After some light scrubbing:
    Pedestal in place:
    1.9's getting some lube:
    Installed:
    When I got to the rear There was a bolt under the upper down pipe. To get to it I had to pry it then finagle the rachet. Ended up being a PITA. Finally I had to disconnect the wastegate from the upper down pipe. This allowed enough movement to pull the valve cover.
    Finally back to the rockers:
    Valve cover was more dirty than the front. Got it cleaned up and reinstalled:
    85 Corvette
    01 TA
    03 Z06
    Buffalo
    Don't forget to use a q-tip to clean up any oil where the rocker bolts go it helps with getting the correct torque
    I would do springs too but that's just me. That way you can do redo seals
  1. ARP lube for rocker install. What for?
    By Rust in forum General Tech Discussion
    Last Post: 12-18-2011, 10:04 AM
  2. 1.9 Modified Rocker Install
    By kissmyss in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-10-2011, 06:59 PM
  3. any Tech Tip for rocker install?
    By Mitchstrp in forum General Tech Discussion
    Last Post: 01-04-2011, 09:56 PM
  4. Rocker install
    By mikesarebetter in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-10-2010, 06:07 PM
  5. 1.9 modded rocker install
    By ExpyGator in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2008, 12:38 PM
