Hopefully you didn't get the same "screw me up" plugs. If you did..pull them and crimp the ends so they don't loosen with heat cycles and cause you KR that drives you to the brink of nuts.
Not that I'd know from experience..but it's a serious ledge at that brink
Like you I picked up on that pretty quick too! A pair of needle nose pliers did the trick. NGK plugs are all the "screw me up" plugs!
