Thread: [10-09-2013 ] 3800 swap&topswap Complete!
Page 5 of 7 FirstFirst ... 34567 LastLast
Results 81 to 100 of 124
  1. #81 Re: [update 5/16/12 ] DOHC died, 3800 swap in progress. !! PICS ADDED!!
    You have no fuel !1!1!1!!1!1!!!
  2. #82 Re: [update 5/16/12 ] DOHC died, 3800 swap in progress. !! PICS ADDED!!
    Florida
    Ok so time for an update.
    Looks like I will be doing the swap next month! The heads are all done. I ported them, seated/ lapped the Si valves, installed new seals, and installed the springs. All cleaned and painted. The tb is basically done being ported and I just started porting the sc today. The outlet is looking great! I might be able to get started in the inlet today too. The lim was gasket matched to the heads. So pretty much the air coming in will have a very smooth path to follow. The exhaust is really good too along with the headers, I shouldn't have any issues there. I got a parts list together of what I still need:
    -sc belt
    -AN steel fuel lines
    -install pulley on blower
  3. #83 Re: [update 09/12 ] 3800 swap
    GT Level Member mkyota1's Avatar
    Daytona, florida
    Let me know whenever you need to use the pulley puller/installer.
  4. #84 Re: [update 09/12 ] 3800 swap
    Hop to it.
  5. #85 Re: [update 09/12 ] 3800 swap
    Florida
  6. #86 Re: [update 09/12 ] 3800 swap
    What's with your maf on your tb?
  7. #87 Re: [update 09/12 ] 3800 swap
    Florida
    It's gone! You noticed huh? I have an external MAF I'm using. I blocked off the MAF hole and put a monte carlo shield in top.
  8. #88 Re: [update 09/12 ] 3800 swap
    Jan 2009
    Tallahassee, FL
    Sooooo what is going on with this build? Completely forgot about it.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  9. #89 Re: [update 09/12 ] 3800 swap
    Florida
    Nothing lately. Time and money have put a delay on installing everything. Hopefully this summer I will get it all in. I pretty much have everything except for the sc belt, new wide band sensor, and upgraded fuel lines I want to do. In the mean time I have had fun tuning it with the hv3 and other mods.
    Bunnell, FL
    If you need any help our anything hit me up
    I live right on the Palm coast / Ormond line
    I'm a Sex Offender
  11. #91 Re: [update 09/12 ] 3800 swap
    Donating Users JLiss's Avatar
    Dec 2012
    Aurora, IL
    subbed
    2009 mazdaspeed3-self tuned Cobb AP,Custom water to air IC,3" intake, 3" DP' 3" exhaust, Forge Wg actuator, Ricer mods, Cobb suspension
    2004 mazda 3-custom big turbo kit, blew up 4x went back stock (Details/pics ask)
    1997 GTP S/C 3.4 pulley, intake, all i know so far.
  12. #92 Re: [update 09/12 ] 3800 swap
    Florida
    Ok here is a newer update:
    I took the car for a run at the track to set a base line before and after for the upcoming topswap. Current NA mods are:
    -mild ported TB
    -HV3
    -SD headers w/ custom 2.5" exhaust
    -180* stat, FWI
    Results!!! 14.953 @ 91.47mph w/ 2.162 60' time Not as fast as my Old PB with the DOHC, but I did not remove my spare tire, jack, tools, speaker box, had 3/4 tank of gas and I have put on about 30-40lbs since that time.... the car did quite well.
    The current plan is to install the top swap this summer. I have read that top swapping is said to lower 1/4 about 1 full second. with the extra mods im planning I hope for just a little more. The plan is for:
    -Ported heads Complete
    -Ported Blower In progress
    -Northstar TB In progress with blower
    -L76 Springs Planned
    -1.9 Roller rockers Optional
    [10-09-2013 ] 3800 swap&topswap Complete! Attached Images
  13. #93 Re: [update 09/12 ] 3800 swap
    Jan 2009
    Tallahassee, FL
    Slowly but surely, good to see you haven't given up. For the top swap you really do need some kind of valvetrain modification. I didn't have the money to go with a cam so I found some YT 1.8 rockers for a good price.
    77 Morris Garage B
  14. #94 Re: [update 09/12 ] 3800 swap
    Florida
    I had a set of SLP 1.8 roller rockers that i sold when i was between jobs. Im thinking about 1.9 rr now. or wait and do a GT1 or GT2 cam a year or so after the swap. But in the mean time the port work on the heads and the Si Valves should help.
  15. #95 Re: [update 09/12 ] 3800 swap
    Jan 2009
    Tallahassee, FL
    I forgot about your port work, that'll definitely help out.
    77 Morris Garage B
  16. #96 Re: [update 09/12 ] 3800 swap
    Florida
    Work in progress.... North star tb matched to m90
  17. #97 Re: [update 04/14 ] 3800 swap
    Florida
    Ok more updates: I just got a set of L76 springs from the dealer today. the other day I finished and cleaned the SC case, rotor pack, and snout on the parts washer at work. To my surprise the SC had the upgraded green coupler already inside. I have a new one but will keep this one as a spare. I will be putting the blower together soon. I need to figure out the type of sealant needed to seal it all. the snout does not have a pulley on it. and the snout that has a pulley, the paint is chipping off. I don't want to have to change the oil twice and reseal it all again... so I'm thinking I will just get an MPS and put that on the better snout i have. Which leads me to a possible early mod 3.6" mps. So does it look like i have enough mods for the 3.6" I know scanning is the only way to be sure but with the mod list i have below a 3.6" should be ok right?
    L36 bottom end
    Ported Heads, L76 springs, Si Valves, viaton seals
    Port matched Lower intake
    Ported Gen 3 M90
    matched to a North star TB. will be starting with a ported L67 TB first and doing a comparison.
    3" MAF from my DOHC
    Speed daddy headers
    High flow 2.5" exhaust with High flow cat and magnaflow muffler
    4t65e with 3.29's
    180* stat
    104 plugs
  18. #98 Re: [update 04/14 ] 3800 swap
    Jan 2009
    Tallahassee, FL
    Yay progress!
    For sealing the snout I just used regular RTV.
    Cam or rockers going on the car?
    77 Morris Garage B
  19. #99 Re: [update 04/14 ] 3800 swap
    Anaerobic sealer in the snout. Try the 3.6 worse case is you need to buy a 3.8
  20. #100 Re: [update 04/14 ] 3800 swap
    Florida
    No cam or rockers at this time. I'm hoping the ported heads, blower, and headers, full exhaust; will allow me to run the 3.6" also with colder plugs, 180 tstat, and tuning.
  1. Top swap 3800 SE
    By Austin2000SE in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-20-2011, 09:51 PM
  2. 3100 sfi swap to 3.4l Dohc
    By Wigsos in forum 3.4L V6 (LQ1) DOHC
    Last Post: 05-27-2010, 03:04 PM
  3. Pics of my swap progress
    By NineD9GT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-04-2010, 02:44 PM
  4. Engine swap - 96' 3.4l DOHC out, '93 3.4l DOHC
    By csbrown in forum 3.4L V6 (LQ1) DOHC
    Last Post: 11-11-2009, 04:47 PM
  5. Supercharged 3800 swap
    By biggz in forum General Tech Discussion
    Last Post: 09-06-2009, 03:07 PM
