Thread: Header install tick
Results 1 to 17 of 17
  1. #1 Header install tick
    KSteelwheelzJ klj5022's Avatar
    New Carrollton,MD
    EGR Leak if after header install tickng soounds like its coming from rear valve cover?
    Is it bad for car or just performance?
    I just wish the police loved my car as much as i do 3.5,160 Stat,HAI,ZZP F/R STB, SSAC Headers, Reptile PCM
  2. #2 Re: Header install tick
    make sure you dont have ay exhaust leaks first.
    But Im betting its the flex pipe ticking, because that right behind the motor.
  3. #3 Re: Header install tick
    New Carrollton,MD
    Check all other joints
  4. #4 Re: Header install tick
    New Carrollton,MD
    Bump anyone got an answer for if its bad for the car or just performance and will it bring down gas miles?
  5. #5 Re: Header install tick
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    I get leaks from my first front and rear exhaust clamps (speed daddy headers). I seafoamed my car 2 days ago and i had smoke coming from under the clamps. What can i do?
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
  6. #6 Re: Header install tick
    Florida
    Headers tick...sort of the nature of the beast.
    Make sure you dont have any exhaust leaks first. Get under the car and listen/feel for any. If any are found, fix them. Then go from there.
    GOTIT, if you used Band clamps, you can take them off, and use some copper RTV, and cover where the pipes meet, and reclamp. I did that to one joint, and never had any issues again.
  7. #7 Re: Header install tick
    Bowie, MD
    ok what kind of rtv should i use?
  8. #8 Re: Header install tick
    New Carrollton,MD
    Quote Originally Posted by GOTIT4CHEAP16 View Post
    Copper High temp RTV
  9. #9 Re: Header install tick
    KJ.. are you anwering your own post questions?
    Tick is part of a single wall flex. If you put headers on ... which you don't say which ones. Then you might have tick. You might have a leak, you have to get back under the hood and take a look
  10. #10 Re: Header install tick
    Bowie, MD
    cool thanks guys
  11. #11 Re: Header install tick
    New Carrollton,MD
    No GOITFORCHEAP thread jacked was answering his question to get him gone LOL
    I have SSAC headers
  12. #12 Re: Header install tick
    Donating Users jacobmh27's Avatar
    Naugatuck CT
    SSAC Ticked like crazy till I replaced the Flex from ZZP. Now it is awsome no tick
    http://www.cardomain.com/ride/3059486
    2001 GTP, TransGo shift kit, SSAC Headers, AeroForce Scan, TDC Racing FWI, Overkill PCM, 3.4 Pully,MSD Coil Packs, Moroso Wires, AL104's, 160Tstat
  13. #13 Re: Header install tick
    Bowie, MD
    lol
  14. #14 Re: Header install tick
    Naugatuck CT
    I can not get the stupidd flex to seal to the u bend real well with theat stupid ass clamp seems like it still leaks did you use RTV on that too.
  15. #15 Re: Header install tick
    New Carrollton,MD
    ook im pretty sure its coming from EGR because today i swear i could feel the tick in the egr when i touched it
  16. #16 Re: Header install tick
    Sep 2011
    MI
    All the EGR does is put exhaust gases back into the combustion chamber to burn off extra emmissions and any fuel that wasn't burned the first time around... It can affect fuel milage, probably not drastically though. Any time you have an exhaust leak before an 02 sensor, it can cause drivability issues.
  17. #17 Re: Header install tick
    New Carrollton,MD
    took the whole egr out and did the penny trick. Tick all gonee
  1. SD Header Install Soon...
    By theshznt69 in forum 04+ Specifics
    Last Post: 05-23-2010, 05:28 PM
  2. ZZP Header Install
    By Xorbex in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-12-2010, 09:08 PM
  3. Header Install
    By GP_Kid18 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-02-2009, 11:12 PM
  4. S&S Header Install
    By GRANDPRIXFOOL01 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-23-2009, 09:57 PM
  5. OBX Header Install is Done!!
    By Uno99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-14-2009, 12:43 PM
