Thread: SC Fill Plug striped
Results 1 to 14 of 14
  1. #1 SC Fill Plug striped
    Donating Users jacobmh27's Avatar
    Naugatuck CT
    Basically what the title says. I was going to change the fluid in the SC for the first time i have owned the car and I noticed the Allen hole is stripped. Any sugestions on how to get it out with out drilling. Dont want to get any pieces in the SC.
    http://www.cardomain.com/ride/3059486
    2001 GTP, TransGo shift kit, SSAC Headers, AeroForce Scan, TDC Racing FWI, Overkill PCM, 3.4 Pully,MSD Coil Packs, Moroso Wires, AL104's, 160Tstat
  2. #2 Re: SC Fill Plug striped
  3. #3 Re: SC Fill Plug striped
    Naugatuck CT
    Good Idea. Dremel pehaps
  4. #4 Re: SC Fill Plug striped
    Florida
    how bad is it stripped.... could u use a std or metric hex on it? or a Torx?
    96 Z34 (RIP LQ1 [email protected]) L36 Swap [email protected] www.cardomain.com/id/z34phoenix
    Topswap: P&P All,Si Valves,L76's,LW Pushrods,SD's,DHP PT PB [email protected]
  5. #5 Re: SC Fill Plug striped
    Charles City, IA
    Pound in the next size hex that is close to fitting
    SMGPFC Two Nipple General
  6. #6 Re: SC Fill Plug striped
    Feb 2009
    flintnasty MI
    Quote Originally Posted by TheOtherNick View Post
    That wont work.
    Slot it, or just leave the oil alone... Changing it never really saved anyone anything IMO.
  7. #7 Re: SC Fill Plug striped
    Naugatuck CT
    I will try and slot it. I ordered the New Plug already will have it on monday
  8. #8 Re: SC Fill Plug striped
    That wont work.
    Obviously it won't...since I've done it plenty of times...and I did it last night on a buddy of mines Cobalt who needed the S/C oil changed...dealer might have stripped it out or maybe the previous owner? Who knows...all I know is as long as your not using an aluminum hex...it'll be fine. All I know is you can't just say "leave the blower oil alone"....Because it, just like every other lubricant needs to be changed eventually...also, if your snout seal is bad...and the blower happens to leak...you have to service it and re-fill it eventually.
  9. #9 Re: SC Fill Plug striped
    Bastard Reptile's Avatar
    Kansas City, MO
    Easy out works wonders too.
  10. #10 Re: SC Fill Plug striped
    try a torx drive , i thought mine was a Allen key but it was torx.
  11. #11 Re: SC Fill Plug striped
    GT Level Member SliceTheRice's Avatar
    South Jordan, UT
    Same thing happened to mine and an easy out took it right out no prob.
    2000 Pontiac Grand Prix GTP
    (3.4 MPS, DHP 1.0 tune, ZZP Plog & 3" DP, 2.5" cat-back exhaust, resonator delete, AL104 plugs, 180* T-stat, Falken Ziex 245/45/18 tires)
  12. #12 Re: SC Fill Plug striped
    Naugatuck CT
    getting the new plug tonight and I will try the easy out. Wanted to wait and get the new Plug. 7 bucks including tax before I got the old one out
  13. #13 Re: SC Fill Plug striped
    St. Cloud, MN
    I just used a bigger flathead and hammered it in and turned it out.
  14. #14 Re: SC Fill Plug striped
    Naugatuck CT
    Well task completed used the easy out and came right out. Changed the Fluid and put the new plug in all done thanks
  1. how do i fill silencers
    By DOUGLASMELTER in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2011, 06:05 AM
  2. HELP striped rear exhaust flange stud
    By kurt5153 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-14-2011, 07:37 AM
  3. S/C Fill Plug Seal
    By VinceJE in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-23-2009, 09:17 PM
  4. How to fill cylinder with air?
    By TheOtherNick in forum General Tech Discussion
    Last Post: 01-15-2009, 11:55 AM
