Thread: Gen V IC Stuffs
Results 1 to 20 of 24
  1. #1 Gen V IC Stuffs
    Vancouver, WA
    I've been bugging Matt about this and he's been a big help but I figure I'd post this too.
    I have a WBS IC and realized that the only place the air from the BBV has to go is the tiny gap from the SC gasket. I haven't removed my H bar. Will this have much effect on daily driving?
    I have had an odd RPM issue since the IC install but it only happens when I'm not in boost. In boost no issues. Could the H bar still being there cause any issues?
    Slowest 'Cooled Gen V ever
  2. #2 Re: Gen V IC Stuffs
    Portland Oregon
    Hey David, I'm pretty sure the intercooler core goes about halfway into the boost bypass circle so you should be ok. However, if you have the blower off, snap a pic for us.
  3. #3 Re: Gen V IC Stuffs
  4. #4 Re: Gen V IC Stuffs
    Florida
    yeah from the mark where you see the whole from the BBV opening it is like 98% covered!. my idea would be to cut the Gen V and noch out that area so the air flows toward the IC core. unless there is space in the two haves of the IC to install a piece of tubing... but to me that sounds like it could cause a leak where boost may slip past the core... or worst yet the pipe break loose and fall into the engine. noching the blower is the safest bet i think
  5. #5 Re: Gen V IC Stuffs
    GTX Level Member 97gtsc's Avatar
    Jul 2008
    Livonia MI.
    Quote Originally Posted by Z34Phoenix View Post
    I did this to my buddys gen3.. The ic is partially blocking that area! But not no more!!
    And wile your there u can cut out the H bar too!!
    Mercer, Pa
    You could drill a hole like they have now. The picture on there website is one like you have but they ship with the milled 1/2 hole.
    From WBS website
    Buffalo
    Yeah it should def have a cut out That dont seem right
    Btw. That's why we use right stuff sealer and not garlocs anymore
  8. #8 Re: Gen V IC Stuffs
    Vancouver, WA
    And from talking to Matt earlier, wouldn't grinding down the H bar do the same thing as drilling a hole in the core?
  9. #9 Re: Gen V IC Stuffs
    Vancouver, WA
    Hmm, so I need to grind down some of the are by the BBV. What are right stuff gaskets? Or is that just modded stockers?
  10. #10 Re: Gen V IC Stuffs
    Vancouver, WA
    Is it safe to just drill a hole in the core? I'd be scared of it cracking or the like.
    Crazy guy, what is all that liquid looking stuff all over your gaskets?
    Mercer, Pa
    You will have to grind by the butterfly valve, that is where the opening is the smallest. The H bar is above Intercooler opening and isn't the problem for BBV. Removing H bar will help air flow through Intercooler.
    Buffalo
    That's oil seepage from the pcv. The rest is just cleaning fluid.
    Garlocs seem to wick oil rather than block it
    Also I didn't take my H bar out cause IMO the air blows down not sideways
    Mercer, Pa
    Right stuff is just a brand of RTV.
  14. #14 Re: Gen V IC Stuffs
    cures in 1 hr vs 24. skins in 5 min vs 60.
    expensive though.
  15. #15 Re: Gen V IC Stuffs
    Vancouver, WA
    Okay. The only thing that scares me about RTV is I feel like I'm going to forget to put it somewhere. So it goes around IC hole, BBV, PCV, EGR. Anywhere I'm missing?
  16. #16 Re: Gen V IC Stuffs
    Vancouver, WA
    So you guys suggest no gaskets and that stuff or both?
  17. #17 Re: Gen V IC Stuffs
    RTV only.
    right stuff is better, so if you can afford it.
  18. #18 Re: Gen V IC Stuffs
    holes.
    Granted your bead is properly sized, the only downside is you're wasting a product which goes bad from sitting once opened and it makes gasket prep more time consuming in the future.
  19. #19 Re: Gen V IC Stuffs
    Vancouver, WA
    Do bolt hole count? Lol.
    Doesn't RTV stay good as long as you recap the tube?
  20. #20 Re: Gen V IC Stuffs
    Cap doesnt seal 100%, dries out around the cap.
    If you get a tube, it will break sooner or later.
    Seems like I always break them before they're all used up.
