I'm having an intermittent stalling issue on my car only while driving. The problem is something is disabling the injectors. I know this via scanning my car with hptuners. Ive replaced crankshaft position sensor. Ive swapped MAFs no help. Ive tried a new pcm, no luck. Ive checked all grounds and are good. Car still has issues. Its like driving your car and just turning the key to the off position. There is no hesitation it just instantly shuts off, all the lights and stuff stay on though just the engine dies. So you have to pull to the side of the road with no power steering and let the car sit for atleast 10 seconds before it will start. And once it does start back up, if i give it alot of throttle on take off it dies again. But if i slowly take off the car will drive good for a few minutes then die again. On another forum, there is a member who has the exact same problem as me and has swapped the same parts as me. But he even went as far as swapping the ICM and camshaft position sensor. We both are stumped. Oh and we both have tried fuel pump resistors, thats not the problem. The problem isnt in the fuel pump, the pump has constant pressure and is running fine. Like i said before its something shutting the injector pulse width off. ANY ideas?
