LTFT thread i made last week http://www.grandprixforums.net/ltft-...uge-51820.html
Okay so ive been having some problems with me car like surges at idle, weird ltfts etc. I went and bought a fuel pressure gauge this morning from advanced and hooked it up but i got nothing when i turned the car on or cranked it up. No pressure at all. ZZP modded fuel rails installed.
When the car was on i was also seeing small white smoke but was only for a few seconds
Dont know what else to do. Also this is a new engine with 53k miles on it because my last engine had a cracked flex plate but sits in my garage at the moment. I had to swap my i/c lim over to the new one along with the supercharger so i changed the LIM Gaskets with the new aluminum ones from advance auto parts.
My LTFT'S are still weird and off and in the positives but i dont know where sle to check for a vacum leak..?? I checked the PCV and it is fine and gasket is still on it, i have AL104's gapped to .55 brand new, checked all the vacuum lines and they are good and not cracked. And if it helps, i have a ZZP modded fuel rail installed on the car. I still have my stock FPR also.
