Thread: oil channel plug missing from block 98 GS
Results 1 to 6 of 6
  1. #1 oil channel plug missing from block 98 GS
    Donating Users Regalgs98's Avatar
    Aug 2008
    hamilton,oh
    So I have repeatedly had this issue wwith losing oil knowing my engine never used/burned any until this last oil change. I started having this issue with oil all over the front of my engine too. Nothing insane but it started affecting my belts badly. Tonight i had a suspicion about a threaded hole right under my intake manifold and washed everything down at the car wash. Sure enough i had another light trail leading down from it after returning home. so i popped the hood on my 98 GTP and it has a hex plug in the same hole. I am guess it is a return port since I never got any negative side effects and its been atleast 4k miles.
    Anywho, does anyone know the thread pitch sizes for this hole so i can fill it? or if all 3800's have this. I could easily swing by the Pull and pay after work.
  2. #2 Re: oil channel plug missing from block 98 GS
    Are you talking about the hole next to the coil pack, just above the timing cover/water pump area?
    On this Bonneville motor, there's a stud in it. On a GP, you either need a plug or it's a bolt for the ground.
  3. #3 Re: oil channel plug missing from block 98 GS
    Aug 2008
    hamilton,oh
    thats exactly it. I guess i've gone longer without it than i thought and just lost more oil from it this time around. The motor in my regal is from a 98 bonneville ssei so i guess when my buddy switched accessories during the swap he didn't catch it. As well as myself...
    Thanks Bill! Huge help!
  4. #4 Re: oil channel plug missing from block 98 GS
    It's probably a 10 x 1.5 thread. Nearly any GM bolt that's the right size will work.
    IIRC that's where the ground wire would typically go on a stud and nut situation.
  5. #5 Re: oil channel plug missing from block 98 GS
    Aug 2008
    hamilton,oh
    good to know, i probably have a couple around. If not i'll just pull the one in my gtp and head to the hardware store. Thanks for all the help bill!
  6. #6 Re: oil channel plug missing from block 98 GS
    make sure to put some sealant or RTV on it when you put it in.
  1. Fuse box missing female plug?
    By Mitchstrp in forum General Tech Discussion
    Last Post: 10-24-2010, 12:45 AM
  2. Noise with 4 channel amp.
    By WhiteGT in forum Audio, Security & Visual Electronics
    Last Post: 05-17-2009, 04:51 PM
  3. mono amp vs two channel
    By comongoose in forum Audio, Security & Visual Electronics
    Last Post: 03-20-2009, 12:04 PM
  4. any interest in setting up IRC channel?
    By fst in forum Forum Bugs/Suggestions
    Last Post: 12-13-2008, 02:56 PM
