Thread: 5* of KR and a bit of mis at WOT
Results 1 to 13 of 13
  1. #1 5* of KR and a bit of mis at WOT
    Apr 2011
    sudbury
    hey guys finally got all the parts installed on the car :
    - Aero force scan gauge
    - boost gauge ( getting 8psi on 3.4 Pulley)
    - headers. 3 inch down
    - thermstate 180
    - AL 104's gapped at 52.
    - overkill tune pcm
    - 3.4 pulley
    - cat back exhaust
    - open cone K&N kilter 4 inch inlet.
    - NGK wires.
    - running on ultra 94 octane that i found in my city and rarly on 91 oct.
    OKAY! now to start im getting rough 4-5*KR at WOT which isent too good. the power is there tho. and im also getting hesetation like a misfire only at WOT. what could this be wire new plugs new and all gapped corrrectly.
    why am i having soo much KR? after putting on all the mods? an soo low of boost like 8 psi on 3.4 pulley isent right..
  2. #2 Re: 5* of KR and a bit of mis at WOT
    Jul 2011
    Edmonton, AB
    Did it begin happening after the new plugs and wires were installed? 8 psi on 3.4 seems ok to me, headers and exhaust will decrease boost due to less restriction..
    Wizaired CAI, ZZP Headers & DP, SLP cat-back, 1.8 RRs
  3. #3 Re: 5* of KR and a bit of mis at WOT
    Apr 2011
    sudbury
    no kr was always there. i would hate to upsize my pulley again because i love the power...
  4. #4 Re: 5* of KR and a bit of mis at WOT
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Need a better tune. If upping to a 3.6 kills the KR then your probobly making more or the same power
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  5. #5 Re: 5* of KR and a bit of mis at WOT
    Omaha, NE
    What mods is the tune for?
  6. #6 Re: 5* of KR and a bit of mis at WOT
    Apr 2011
    sudbury
    Its the over kill pcm 4.2 i think
  7. #7 Re: 5* of KR and a bit of mis at WOT
    Huh...
    http://www.grandprixforums.net/chipp...mon-51934.html
    http://www.grandprixforums.net/al-10...res-52049.html
    http://www.grandprixforums.net/97-gt...wer-48080.html
    Anywho...
    8psi is fine. The problem is it is elsewhere. Are your mounts bad? Is your front sway bar flipped upside down to avoid the downpipe hitting it?
    Check those.
    Also...AL104's gapped anywhere from .050"-.055" would be fine.
  8. #8 Re: 5* of KR and a bit of mis at WOT
    Which cylinder are the misfires on? I'd think that's where you'd concentrate your efforts.
  9. #9 Re: 5* of KR and a bit of mis at WOT
    Pennsylvania
    The gtp's Overkill tune was rather too rich. Probably ~10.5afr wot. Saw plenty of KR (4-7*) at the top. Might be worthwhile to look into that.
  10. #10 Re: 5* of KR and a bit of mis at WOT
    Apr 2011
    sudbury
    downpipe dosent hit the sway bar at all. i heard some people had that issue. but i never had issues with that. illl change that coil pack and go from there...
  11. #11 Re: 5* of KR and a bit of mis at WOT
    Apr 2011
    sudbury
    i went to toronto yesturday to try and find will (overkill motorsports) shop and there was no luck. its like its unlocatable
  12. #12 Re: 5* of KR and a bit of mis at WOT
    GT Level Member Overkill's Avatar
    Nanaimo British Columbia
    I had sent you an email regarding that. Its a mailing only address, all you'd find is a UPS Store.
    I'm certainly available for in-car tuning if you'd like me to have a closer look at the vehicle, we just need to make an appointment. I'm booking just over a week in advance at the moment (track season, busy).
    Email all inquiries to willoverkill@gmail.com!
  13. #13 Re: 5* of KR and a bit of mis at WOT
    8 psi at 4000 rpm or 5700 in second gear?
bit, mis, wot
