Thread: Oil pressure kits
Results 1 to 15 of 15
  1. #1 Oil pressure kits
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    I've been searching and can't find any details about the spacer used. Anyone know if it's hardened, or how thick it is?
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  2. #2 Re: Oil pressure kits
    for a gauge? it just screws into the where the oil pressure sensor is. done. unplug stock sensor, toss in the trash.
  3. #3 Re: Oil pressure kits
    GTP Level Member lambokit's Avatar
    Apr 2009
    Radford, Virginia
    Or screw in a brass "T" and have the stock sensor and a mechanical gauge.
    Lambokit to be built!!!!!
  4. #4 Re: Oil pressure kits
    May 2008
    staten island,NY
    the stock sensor is useless. if you do add the pressure gauge make sure you splice the 2 factory wires together from the plug so the oil light doesn't come on the dash
  5. #5 Re: Oil pressure kits
    Hit photobucket
    Id billboost37
    Pswd Boosted
    Look under oil pressurd for all that info in pics
  6. #6 Re: Oil pressure kits
    Dec 2008
    Alabama
    it's not a gauge. it's a shim that goes in the oil filter housing to increase oil pressure. http://intense-racing.com/Merchant2/...tegory_Code=GH
    there is a little washer. I figure it's $1.50 for the gasket and much less for the washer, so it's not worth it to spend $30 for the kit.
  7. #7 Re: Oil pressure kits
    Charles City, IA
    Its a different pressure spring. Just get an oil pressure relief spring for an 05 gtp same thing.
    SMGPFC Two Nipple General
  8. #8 Re: Oil pressure kits
    Dec 2008
    Alabama
    Oh DUHH! Thanks for that.
  9. #9 Re: Oil pressure kits
    Dec 2008
    Alabama
    I thought this was interesting. GM part number for the new Oil Pressure Spring
  10. #10 Re: Oil pressure kits
    I'm not suggesting anything, but the dorman washer that I use may just be located in those pb pics.
    766-012
  11. #11 Re: Oil pressure kits
    Dec 2008
    Alabama
    Oh a part number too! Thanks. What psi increase did you see and with what viscosity?
  12. #12 Re: Oil pressure kits
    Go check out the vendor sites.. do a little research..lol
  13. #13 Re: Oil pressure kits
    Dec 2008
    Alabama
    hahaha. So what you are saying is you don't know.
  14. #14 Re: Oil pressure kits
    Not at all. "What I'm saying is go do some research." I believe that no one should put a mod on their car if they don't understand it and it's benefits/ramifications. If those were understood and research had been done, you'd likely know the expected gains from the kit.
    Not being a dick (for once), really saying though, that if you want to do something, please understand it.
    As for my experience..it's all dependent on the oil used, idle/high rpm etc etc.
  15. #15 Re: Oil pressure kits
    Dec 2008
    Alabama
    That's why I said what I said in my first post. Which is why I'm not doing anything right now but researching. Kinda the point of the thread. I figured maybe someone here has experience and can give real world info.
  1. HID kits?
    By bziggy58 in forum Audio, Security & Visual Electronics
    Last Post: 06-28-2011, 10:14 PM
  2. JLM HID kits
    By Jakescoots in forum Visual/Body Modifications
    Last Post: 12-31-2010, 10:51 AM
  3. JAW Kits
    By Ibwrong in forum General Tech Discussion
    Last Post: 06-09-2010, 08:23 AM
  4. Check Tire Pressure light on with no low pressure.
    By DanGTP in forum General Tech Discussion
    Last Post: 11-13-2008, 08:43 AM
