Thread: Any differences in the bottom end between L32 s/c and n/a?
Results 1 to 5 of 5
  1. #1 Any differences in the bottom end between L32 s/c and n/a?
    SE Level Member Porach's Avatar
    United States
    Any differences in the bottom end between L32 s/c and n/a? Need another bottom end so im trying to buy a used engine for my build.
  2. #2 Re: Any differences in the bottom end between L32 s/c and n/a?
    Well yeah.
    Because the Supercharged 3800 in '04+ cars is the L32
    The N/A 3800 in '04+ cars is the L26...differences?
    Compression ratio is higher in the N/A car (8.5:1 vs. 9.4:1) and the rods in the L26's are tiny compared to the L36/32/67 engines.
  3. #3 Re: Any differences in the bottom end between L32 s/c and n/a?
    GT Level Member aligater's Avatar
    london ontario canada
    04 L32 is only an L32 on top, bottom is still L67
    05+ is all the same except pistons on L32 are forged and L26 are not and the difference in compression.
  4. #4 Re: Any differences in the bottom end between L32 s/c and n/a?
    Quote Originally Posted by aligater View Post
    L26 = 9.4:1 Compression
    L32 = 8.5:1 Compression
    L26 rods are smaller than L32 rods...so sit a set next to each other. Oil pan is different...L26 heads and L32 heads flow better and have slightly larger valves as well.
  5. #5 Re: Any differences in the bottom end between L32 s/c and n/a?
    none of the motors got forged rods. they are powdered rods in L32/L26.
  1. bottom swap, or how i learned to rebuild the bottom end completely
    By almighty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-18-2009, 03:37 AM
  2. bottom end
    By rodman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-27-2008, 11:01 AM
  3. Out The Top or Through The Bottom
    By SyntheticShield in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-20-2008, 01:07 PM
