Thread: hard starting
Results 1 to 7 of 7
  1. #1 hard starting
    SE Level Member Moriarity81's Avatar
    Aug 2011
    Michigan
    hi this might be a stupid question but im not sure. i was woundering if my alternator would have anything to do with my car starting hard? its been sitting for a couple weeks and when i went to start it the other day the battery was drained so i jumped it and let it run for a couple mins shut it off and it started right back up so i shut it off came back a couple hrs later and it was drained agian. also i noticed since ive owned the car that when i start it it starts kind of hard like dosent want to turn over but it always did. i have a general knowledge of how stuff works in an engine and every thing im just not positive wether or not the alternator could b the solution for both my problems or even one at that lol.
  2. #2 Re: hard starting
    Omaha, NE
    Sounds like your alternator is bad. Its main job is charging the battery and it sounds like that's not getting done.
  3. #3 Re: hard starting
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    Is the alternator making a unusually loud whirring sound? That would confirm my suspicion that the diodes are bad. That will take out the battery too. Check to see that your trunk light goes off when you close the lid.
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  4. #4 Re: hard starting
    test the battery first, do a CCA test on it to make sure a cell is not dead.
    If the battery checks out, it could be the alt.
  5. #5 Re: hard starting
    Aug 2011
    Michigan
    i dont notice any weird noises comming from the alternator or anywhere else and what is a cca test?
  6. #6 Re: hard starting
    cold cranking amps.
    you need a battery tester to do it, autozone should let you use it or o'riellys.
  7. #7 Re: hard starting
    Aug 2011
    Michigan
    Alright thanks for all thw info ill go through and check everything make a trip to autozone to have a cca test and let you know what happens
  1. 2007 Grand Prix Starting Hard
    By packerfanjc in forum General Tech Discussion
    Last Post: 06-13-2011, 10:22 PM
  2. Carbon Build up / hard starting
    By john breit in forum General Tech Discussion
    Last Post: 03-07-2011, 02:46 PM
  3. 98 gtp hard starting rough idle
    By 98BlknSlvrGTP in forum General Tech Discussion
    Last Post: 01-17-2011, 10:10 PM
  4. Help Car Hard Starting
    By rstark in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-15-2008, 06:24 PM
  5. Has a really hard time starting when engine is hot
    By spenc938 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-05-2008, 11:27 PM
