Thread: looking into gen5 swap
Results 1 to 9 of 9
  1. #1 looking into gen5 swap
    GT Level Member nicks98gtp's Avatar
    michigan
    ive recently started looking into a gen 5 swap possibly, instead of rebuilding/upgrading my gen 3. Im just trying to clear up what all is needed for the swap, is it just the LIM/tb adapter/and s/c, or is there more to it than that? thansk for any help
    98 Gtp, ported s/c, fully rebuilt motor .20 oversized pistons, rebuilt trans, zzp pcm,more mods to come
  2. #2 Re: looking into gen5 swap
    Charles City, IA
    Then you need to make the pcv system work and block off evap or make it work also. Then you need a 2000 plus alternator bracket.
    SMGPFC Two Nipple General
  3. #3 Re: looking into gen5 swap
    michigan
    how dfo i go about the pcv thing? and the evap thing? that probably sounds dumb, but im unfimiliar with the gen 5 as i havent personally seen one, except for pictures. i would guess same concept but i may be wrong
  4. #4 Re: looking into gen5 swap
    Waukesha, WI
    nick isnt it 99+?
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  5. #5 Re: looking into gen5 swap
    Mercer, Pa
    You can use the L67 manifold but it is best to open up the inlet opening to match the gen 5 gasket. To get the PCV to work you have to drill out a brass plug on you throttle body.
    See my thread
    http://www.grandprixforums.net/how-g...her-44478.html
    Without an intercooler you attach to the nipple on the back of the gen 5 supercharger.
  6. #6 Re: looking into gen5 swap
    Charles City, IA
    Also you can tap your throttle body spacer and run a hose from that. Just need metered air to go into the pcv nipple. To get the evap to work I would try to get a gen v with the evap line on it then you can run a hose to your solenoid.
  7. #7 Re: looking into gen5 swap
    Mercer, Pa
    Quote Originally Posted by TheOtherNick View Post
    NOOOOOO. You need air from between throttle body and mass air flow. If you tap the adapter you are connecting both sides of PCV to same place and getting no air flow also will put full vacuum to crankcase.
  8. #8 Re: looking into gen5 swap
    GT Level Member aligater's Avatar
    london ontario canada
    The N* TB has a nipple on it, just put a hose to the nipple on the Gen V.
    The last one I did had a 90deg quick/push connector threaded into the EVAP on the Gen V and used 3/8's plastic fuel line from that to the stock EVAP soleniod mounted to the back of the Gen V.
    I have an adapter plate and TPS adapter if needed, can get pics if needed.
  9. #9 Re: looking into gen5 swap
    Minnesota
    Has to be before the blade on the TB.
  1. Ported gen5 and phenolic intercooler
    By 2007gpgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-28-2011, 05:51 PM
  2. top swap a gen5 to a 98 NA GP
    By 16MustangVet in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2011, 08:58 PM
